Wen track saw - initial user impressions
Henry (Raleigh NC)
I bought a Wen track-saw and PowerTec track (2x55"?) and a few clamps. Here are a few new-user impressions and comments.
1. Saw is mostly plastic construction (exterior and controls) - and once you get past the perception that gives, it works just fine as a saw.
I do not expect to use this tool often, so this is a trial. If, like some other tools (impact driver, cordless osc. tool) I find I have real uses for it, then I can justify an upgraded tool. I expect this saw will work fine for me.
2. The plunge depth control knob can be somewhat awkward for the 'fat-fingered' like me.
3. The anti-kickback cam (in the track) caused me difficulty with both seating the saw and moving it in the track.
A tag on the saw describes this as removable (at more risk), and so I did remove it; the saw seats more cleanly and runs in the track much more smoothly without that feature installed. I had been 'fighting' to move the saw along the track, and that was much more of a safety issue (to me).
Smooth operation within expectations is a great 'safety' feature.
4. Since I did not have #3 figured out on my first few cuts, the rubber splinter guard is not exactly cut to the line now.
I presume these are replaceable - as now that I know how to use the system, I would like new ones. I should have FIRST run the saw on the new tracks without cutting any wood (to cut the splinter guard ; that may be in the manual (which I must have missed when I read it through 3x - haha!).
5. Dust collection is quite good for 'buried cuts' when using a backer foam sheet, AND covering the blade access hole with tape. I used my existing Ridgid shop vac and current hose (a non-Ridgid extension), which has a rubber end that fit nicely over the saw port.
For a cut that 'skims the edge' dust is thrown laterally, just like on a TS, and dust collection suffers considerably.
6. PowerTec (sp?) tracks linked together seamlessly - the few times I have done this.
7. Saw does not (seem to) have the power to cut 2 stacked sheets of 3/4" plywood - it bogged down and the motor heated up. Of course I was simultaneously having tracking issues, but even once I cleared the tracking (see #3) it balked at the 1.5" depth. However my first cut on a stack worked OK, but the second one did not; maybe the hot motor due to tracking issues was the issue(?). I may retry, as stacking sheets makes for decent 'identically sized pieces'. The saw cut cleanly once the sheets were separated and the cut was only a 3/4" sheet.
8. Cutting slowly resulted in a (near) splinter free cut on the top side where the blade emerges. Moving the saw 'faster' resulted in some significant splintering. The material being cut is pre-finished maple plywood. All cuts were very clean on 'the show side' - the bottom side, where the blade/teeth entered the cut (rather than where teeth emerged on the top).
Overall: From a casual and un-initiated tracksaw user, this saw gets a thumbs up from me (especially in terms of value); the longer term performance is of course still an open question.
I read some reviews and watched several review videos before making purchase, and can't recall anything specific, but they gave me the confidence that this would meet my initial need and user expectations. Someday a saw upgrade may happen, but I chose this track as it is compatible with both the Festool and Makita saws, but not DeWalt (IIRC).
Henry
Prolific creator of sawdust, and sometimes shavings - with the occasional completed project.
