ADVERTISE HERE - FREE TRIAL
Veneered Coin Box Completed
CJ in MPLS
A while back I asked for some information on how the Gerstner front lid hinge worked. I was able to use that information in building the coin box below.
The box is veneered with walnut burl and has cocobolo edging. The drawers are side hung and are veneered with camphor burl. The white diamonds behind the pulls are holly.
Each of the drawers is lined with pigskin suede and has a maple grid to separate the coins the new owner collects.
The door rotates around a horizontal axis and slides back beneath the bank of drawers. The hinge was, in the end, not too difficult. That being said, I got a bit too clever for my own good. I could not figure out how to get the door pins into their grooves so I adapted the Lee Valley spring loaded hinge pin concept. This worked great for assembling the door, but the springs push the hinge pins into close contact with the slots routed into the cabinet sides, which makes for a fair bit of friction and sticking. Next time round I'll make the slot a bit bigger.
Cheers,
CJ
Re: Veneered Coin Box Completed
Wow!
John in NM
Very nice work!
I made one of those sliding hinges too once - I got a dry rotted Gerstner box for about $100 and made new sides and bottom for it. No idea if I did the slot right - the original was too damaged to figure out as I recall (this was about 1995 or so). I made little brass pins on my tiny machine lathe and put the front panel in from the back where the slots were open, then put an applied back on the box.
Mine didn't turn out anywhere near as nice as your coin box though!
Virgil Johnson
Nice work.
A Real
Treasure box worthy of the treasure to be inside
Re: Wow!
CJ in MPLS
I recently picked up and refinished a Gerstner chest for my brother's 50th birthday. The slot from that is a bit rough and much larger than the pin that forms the hinge. I will either have to make much smoother hinge slots, or smaller pins.
Thanks.
Clint Searl
Elegant!
Bravo!  A beautiful piece!!
John Jardin
Outstanding craftsmanship !
Paul in NJ
Beautiful! Wonderful selection and application of veneers.
A Stunner!
Very, very nice work!
Bruce, a MN Galoot
You should enter that in the next Northern Woods show whenever they have it again.
What a beautiful piece!
Johanna Johanson
That is one beautiful box. Congratulations!
Gorgeous !
Re: Very, very nice work!
CJ in MPLS
That would be fun. I really do need to get out more.
Questions
Handsome box! But how is the box put together? I'm stumped. Never built anything like this box so no idea how it got assembled. Particularly flummoxed by dark piece at the edges.
What sort of joint joins sides to top?
What's under the veneer?
How did you stick the veneer-kind of glue and what applied pressure? Do you veneer panels and assemble or assemble box and veneer?
Finish (looks just right for this box)?
What is pig suede? It would look nice in my spice boxes.
Re: Questions
CJ in MPLS
Bill:
Thanks for asking. This box is joined using rabbets, though in the next iteration I will use miters to see if there is any difference. There are screws holding the sides to the top and bottom. The screws let me do measurements on the channels for the door hinge. I don't know that I would use the rabbets again as the corner edging (cocobolo) seems to provide a lot of long grain contact. I've also become comfortable enough with the hinge pin set up that I won't need to mess about with disassembling the carcase before glue up.
The veneer covers a Baltic birch carcase. I added a secondary veneer across the back under the burl to avoid having the joints ghost through. I struggled with the veneer a bit as I pieced it together directly on the carcase. I was able to clamp through the open front of the box. I wised up and pieced the veneers for the door together and glued both of those at once, flat on the bench. I was going to add holly stringing between the burl and the quarter sawn walnut border, but ran out of steam. I don't think it suffers from the lack. I still have a bunch of holly strips I need to use up.
The finish is straight up french polish using a 1# cut. I did not fill the pores however.
The linings are very simple and I think look great. Tandy and other places sell pig skin suede in every color of the rainbow. $25 for an entire hide. I used a bit less than 1/2 of the hide I purchased for all of the drawers. I cut bristol board to fit the drawer bottom and then adhere the suede to the bristol board using a fast tack latex craft glue. The suede wraps around the back of the bristol board. I make the bristol board a bit smaller than the opening into which it will be placed to account for the thickness of the suede, but a tight fit is good. I used some hide glue to tack the bristol board down to the bottom of each drawer. Very simple and quick to accomplish. I find that I like using leather/leatherette in projects.
This box took forever. Between prototypes, remaking parts due to error and all of the new stuff I had to learn, it took about 10 months to complete. Now I need to see about making this into a 10 day project rather than a 10 month one.
Cheers,
CJ
Questions
Tom Colligan
Just beautiful, CJ.
I'm looking for a lockset so may I ask where did you buy the lock from?
And, where did you buy the walnut and camphor?
Thanks and please let us see what you've done with the next one.
Tom
Re: Questions
CJ in MPLS
The lock came from Lee Valley. It is ok. Definitely better than stuff you might get at the local hardware store.
The veneer came from https://www.veneersupplies.com
Good luck.
GolfSteve in Calgary
Nice job on the veneering!
Brad Chenoweth
Beautiful box, CJ! I watched a video from the Gerstner site to see how the front is installed on one of their boxes. It's done with the drawers removed, and the front is simply angled to allow the pins to enter the grooves. Looks like the drawer blade in yours would prevent using that method, though.
https://www.youtube.com/watch?v=cw2pvniLe_Q
corner edging
I like the way the edges and corners appear but remain flummoxed about this feature. It looks so good I would like to know how to do it. Is a rabbet cut out after the box is assembled and the cocobolo inserted?
Given the complexity I am not surprised at the amount of time it took to first figure out how to make it and then make it right.
I am excited to see what comes next out of your shop.
Re: corner edging
CJ in MPLS
I cut rabbets around the edges of carcase using a dado blade on the table saw. The edging around the top and bottom was mitered while the verticals were fitted tightly between. The it was a matter of rounding at the router table. The edging is 1/4” wide and the round over bit is as well.
I did a lot of test cutting to ensure success. I also used a cutting gauge to score all of the edges prior to running the dados to avoid tear out.
I believe I got the technique from a FWW article on making a humidor.
CJ in MPLS
I was trying to get the reveals tighter than what I thought I could manage with the gerstner approach. I don’t know if my thoughts on that were correct as there were a few too many independent variables for a definitive answer. I’m hoping to figure this out as I move forward because the door function is kind of neat I think.
Re: corner edging
I cut rabbets around the edges of carcase using a dado blade on the table saw was that stressful? ;)
I feared you were going to tell me that is how it was done. I like the end result but the process is daunting.
