Quality Lasts
Sometime in the dim past (aka more than 15 years ago) I bought a bunch of 3x21 belts in various grits. The idea was to use the belter to take out the heavy scratches left by the P-Max large grits when used for abrasive planing. There was a mix of "Sun" and 3M brands.
Turns out (as Barry knows) some belts seem to have a use-by date that they don't tell you about. Key word here is "some."
Doing a butcher-block counter section for my daughter. After doing the heavy sanding with the P-Max I went to the belt for stage 2. Picked an unused belt from the rack, and started sanding; took all of 30 seconds for the belt to let go. "SNAP!" Grabbed another couple, samo. Number 4, however, was the drum-bunny and kept on going n' going.
Just for fun I checked the 4 belts for brands. Ah Ha! The busted belts were all Suns but No. 4 was a 3M.
Looks like I'll be sorting and rotating out some stock for quality 3M belts. The others will have some use for turnings.
So much for trying to save a couple of bucks.
