OT - Anybody ever use a palm nailer underwater?
Tim Greif - West of Chicago
I know - odd question. At my river place, I need to reinforce some 4x4 dock posts that have hour-glassed at the water line due to oxygen and microbe action just like when you bury a wood post in soil. I'm building box sections to slide over the posts and will need to nail them to the original posts both above and below the water line. Deepest part will be about 3-feet below surface. I plan to use a cheap palm nailer from Harbor Freight. Has anyone ever attempted this?
Re: OT - Anybody ever use a palm nailer underwater?
Steve jenkins
I haven’t but have used a pneumatic jack hammer about 120 feet underwater. Works fine but was hell on the ears. Pressure waves from the operation. I imagine the nailer will work ok. If your head is underwater you’ll find out real quick if you want to keep it there.
Gonna work a lot better than the other options
John in NM
Neither a power drill or a ramset will work.... pneumatic looks like the only thing to try!
I hope you're planning way far ahead :D January is not when I want to do dock work!
Alan Schaffter
Pneumatics and hydraulics work fine underwater, just as long as the pressure differential between the air supply and pressure at depth is greater than or equal to the tool's operating pressure. At 120' the pressure is 51.87 psi so you would only realize 73 psi from a 125 compressor/air hose. You'll likely be no deeper than 2' - 3' deep so no problem.
One problem, depending on the design of the palm nailer is it may need make up air when the piston returns to the firing position if only via spring. In that case water may be drawn into the cylinder, so when you are done flush the nailer with fresh water, lots of air, then pneumatic tool oil. These posts from other websites:
"I used an inexpensive palm nailer from harbor freight today and it worked GREAT!
Was shocked that it worked and didn’t lock up like some replies in this thread indicated it might. I was 7 feet down driving 16 penny galvanized nails through a 2x6 into an old dock pile. Worked great. Good luck."
another:
" I have, since I posted this answer, used multiple cheap pneumatic tools underwater. I can report that I have had no problems at all in doing so, as long as the tool is disassembled within a day (preferably ASAP) after being used and lubricated throughout."
and this from an Amazon page:
"Senco A9 Palm Nailer
Brand: Senco
4.5 out of 5 stars 13 ratings
Currently unavailable.
We don't know when or if this item will be back in stock.
Compact, well balanced
Lightweight, only 2-1/2 pounds
Drives 6d to 16d nails
Works underwater
*Hose and fittings not included
› See more product details"
So there ya go! Be prepared for lots of bubbles.
Pete in Holland MI
Marine contractor that I worked for nearly 40 years ago use air tools under water all the time. Lots of bubbles in your work area to contend with. They worked fine though. Just need to make sure to give them a good drink of WD-40 at the end of the day.
Old school
Jerry Gibbs
Another method would be to pre-drill holes in the repair. Under water insert a couple of 1/4 lag screws, hit them with a hammer, and use a ratchet. Nowhere near as dramatic.
William Duffield
Palm nailer? For under water, you should use a flipper nailer or fin nailer. :D
