Question on leveling slabs for table
J Barrett Irby Jr
I built or modified a contraption for leveling slabs and it worked fairly well. I have two book matched white oak slabs that are 10' 6" long and 2' wide that flare to 40" on one end. I cut off the flare to make the base for a table. Leveled the first one. It started 2" thick and ended up 1 3/4" and flat on both sides. I was impressed I got such a minimal loss. Unfortunately the second one is 2 3/4" thick. I was a little heavier handed leveling it and it remains 2 1/8" thick.
So, if these were going to be the trestles to support your table would you grind away the thicker one to make it the same as the thinner one or would you just leave it alone and let them be mismatched in thickness?
