REAL MILK PAINT
OT__Bird houses
OT__Bird houses
OT__Bird houses
Buck Nall
Down here -deep South Ga. there are snakes! OK! I've built and
put/placed/nailed up 45 Blue bird houses, intend to build and place more!!
OK, mommy bird is setting inside AND MR.SNAKE sticks'ez head in
the entrance hole!!
'ight, how bout boring another hole on one side, an escape hole!! It would
be same size & height from floor/bottom as main entrance hole.
OK. Mommy see'z MR SNAKE & GIT OUT THRU OTHER HOLE??!!!
YEAW, MR SNAKE will swallow the eggs or little birds, but that's life!!
All opinions will be considered, Thank U.
Re: OT__Bird houses
Maybe you could make it snakeproof
Do you think the mama bird could actually have time to escape once the snake sticks his head in there? How about mounting the house on a greased pole or hang it from some kind of rig that a snake can't climb down?
Re: OT__Bird houses
Re: Maybe you could make it snake/squirrelproof
Tom Dunlap
Snake or squirrel...both are creative and hungry.
I found many examples of collars and netting to try and thwart access.
If the snake got to the entrance hole once it'sll get back again. That's too late.
Re: OT__Bird houses
Virginia Bluebird Society *LINK*
Yonak
Check out these suggestions from the Virginia Bluebird Society :
Nest Box Protector Guards
Re: OT__Bird houses
John McGaw
I don't think that squirrel-proof is possible using ordinary materials. Some time back I made eight or ten really nice (if I do say so myself) bird houses in octagon and hexagon shapes. I even gave them copper roofs -- built to last. Yeah, last until the gray squirrels discovered that they could chew right through that good cedar wood and enlarge the bird-sized holes to suit themselves. The last of them succumbed (the bird houses, not the squirrels) after about three years. The first time I looked into one of those enlarged holes and saw those beady black eyes staring back at me...
Re: OT__Bird houses
Snakes climbing pole *LINK*
Lee Schierer in McKean, PA
Scientists have recently discovered that some snakes are adept at climbing poles. Fortunately, The ones that do don't live in the U.S. yet....
Lee
Pole climbing snakes
Re: OT__Bird houses
squirrelproof?
.>>>.. -- built to last. Yeah, last until the gray squirrels discovered that they could chew right through that good cedar wood and enlarge the bird-sized holes to suit themselves.
One hole enlargement prevention is to cut a square of metal with a hole the size of the hole in the birdhouse. Fasten that to the front of the birdhouse. Could be copper or painted steel. Squirrels and other birds that enlarge holes will be discouraged.
Around here, raccoons are another problem for bluebird houses. They can reach inside the hole and grab eggs and little birds for a snack. I sometimes make a 5" cylinder of 1/2" hardware cloth and make 1" four cuts on one end to bend outwards to make tabs that I fasten to the front of the birdhouse with screws. These cylinders are the same size or a bit larger than the required hole size. The birds don't seem to mind. The raccoons can't get their arms in enough to bend down to reach the baby birds. This may stop squirrels tool
Don't know what would work for snakes. A disk on the bottom of the birdhouse and on top the pole with a bed of sharp steel spikes pointed downwards?
