Tried a new tool a couple weeks ago...
John in NM
This is a 1" inflatable drum meant to go in a drill press. Modified for the lathe since I use it less than my drill press and I already had a couple jacobs chucks on a MT2 for the lathe.
I'd never used one of these much, but I have a much bigger one on the other spindle of my flap sander and I've found it useful for axe handles and stuff like that. In this case I needed something much smaller to smoothly finish sand finger grooves on grips I make and the spindle sander drums that work well for shaping are too hard for finish work and leave a scalloped edge. This really does the trick, and has pretty much eliminated hand sanding.
I'm also very impressed with how long the sleeve seems to last, I just did about 60 walnut grips and it's still got life in it - though walnut is of course not as hard on sandpaper as beech - the other wood I use for grips.
Re: Tried a new tool a couple weeks ago...
great tool for sanding rounded work...
David Weaver
....the give in the sleeve below the sanding drum keeps the grit from getting ripped off so fast like it does on a rigid drum and it doesn't leave little facets all over everything. I've noticed that type of drum is often used in small production anywhere that something is being sanded smooth without needing to have crisp lines on them anywhere. I know LN used to use them on handles if they don't still, too.
Michael van pelt
Ingenious! Thanks for sharing
