Question on veneer repair
CJ in MPLS
Glue first or clean first? That is the question.
Earlier today I bought a Gerstner chest. This one:
It has failing veneer on the top and on the back, which I believe is common to these. Luckily, while the veneer is lifting off, it is still present. Hide glue should sort this out relatively easily. The issue is whether the grime on this case should be cleaned before or after gluing?
Since I expect that the damage occurred some time after the chest was in service in an oily environment, the amount of glue defeating crud on the old glue surface is likely minimal. If this is the case, some warmed up old brown glue liberally applied should suffice. But if the amount of grunge on the old glue surface is high, then perhaps some naphtha and gentle scrubbing under the lifted veneer would be good? The issue is that I'm worried about jacking up the lifted veneer by cleaning it before glue. The cleaning fluid is not so problematic, but the action of cleaning may lift or break more veneer than is necessary.
Thoughts?
