1/4" Blade in a Laguna 16HD Bandsaw ?
John Foster
Has anyone put a 1/4" 10TPI blade in a 16HD Laguna bandsaw with the standard ceramic guides? How well did it work?
John Foster
Cutting curves?
Jim Matthews
If you're cutting curves, a sacrificial guide might be useful.
The larger guides overlap gullet and might dull teeth under heavy "twist".
Re: Cutting curves?
John Foster
So how do you make a sacrificial guide? I can imagine that you remove the existing ceramic guide holders with some drilled hardwood blocks fairly tight to the blade and spin by hand until it runs smooth.
Re: Cutting curves?
My old pal Mark Duginske came up with a product called Cool Blocks, which were made of a stiff, graphite-impregnated material that would support even the narrowest blades. I'm betting somebody sells them, though I haven't checked lately.
Re: Cutting curves?
Jim DeLaney, Austintown, Ohio
Back when I bought my Laguna 16" - about 20 years ago - Laguna sold 'cool block' adapters to replace the ceramic guides. Mine are around her somewhere, but I've never used them. I keep a 1" Resaw King on the saw, and use my old 14" Delta clone for thinner blades.
Re: Cutting curves?
William Duffield
The last time I looked, Woodcraft carried them. I think they are now made by Carter. They look like they are made from canvas Micarta, but I'm not sure about that.
When I had a bandsaw that used guide blocks, I replaced them metal ones with lignum vitae blocks the same size and shape as the originals. There was no need to replace the block holders. All my bandsaws now use ball bearing guides. My small bandsaw, which I use for cutting curves, now is equipped with a Carter Stabilizer, which consists of one ball bearing with a groove that supports the back of the blade from above the table, and no guides whatsoever below the table.
The problem with stock guide blocks is if they are adjusted improperly, the blade can be pushed back far enough that the blocks squash the set out of the band's teeth. This doesn't happen with lignum vitae blocks, because the blade cuts its own kerf in the blcoks.
If set too tight (side to side), frictional heating can expand the metal blocks enough to pinch the blade between them and actually bring the saw to a stop. This also heats the blade enough to anneal the teeth, and then they get dull in a hurry. DAMHIKT.
