REAL MILK PAINT
Makita Battery Question
Tom Norton
The original batteries are 18v 1.5Ah. I have found an aftermarket battery but it say 6Ah.
Will I be setting myself up for problems if I go this route?
Thanks!
Re: Makita Battery Question
Ralph Lipeles
The 6 AH battery has 4 times what your battery has. It will last a lot longer between recharges.
Henry (Raleigh NC)
and if it has 4x capacity, it's likely 4x as heavy as well.
Henry
Dick Coers
Who knows if the aftermarket battery really meets that capacity. The use of cheap Chinese cells in aftermarket batteries are very commonly overrated. As long as the voltage is the same, any Ah capacity will work.
John Foster
Make sure any new battery fits your tool before you buy it. For unknown reasons, not all Makita batteries fit all tools ( quite possibly aftermarket batteries as well). My Makita stapler will accept 3Ah batteries but not 4Ah batteries.
Tom Norton
Henry, thanks for that reply! I started looking at some of the pics and can see the larger/heavier size.
Chad Pearson
Be careful with the aftermarket batteries. I have purchased a couple different sets of the 6.0 amp/hr batteries from Amazon. I find that they are not really up to the task of heavy usage (e.g., chainsaw). After very little use the chainsaw stops working.
I have had much better luck purchasing genuine Makita 5.0 batteries. They are more money on EBay than the aforementioned aftermarket batteries, but they last a lot longer in the chainsaw.
Ralph Lipeles
I thought that pretty much all the batteries came from China. Where are the Makita batteries made?
Jim Matthews
They're made by little elves, in a hollow tree.
(My Makita replacements are of the finest Chinesium - they work just fine.)
