A55 Smoothing Plane
OT --Reliable circuit breaker/outlet finder
Gary Smyth
Recently had a larger circuit breaker panel installed. The electrician removed the old box which had the circuits identified. Repeated calls to him have not produced the panel list or even return calls.
I have to work alone and the house seems bigger every day. For the double breaker 220 lines I can work it out. But so far plugged in lights and radios are a pain as I have to leave the panel to find the house (and separate garage and shed) outlet to find if the radio is dead or the light out. This gets old fast -- and at least one minor jolt surprise too!
There are several circuit breaker finders on the market but the price range varies greatly. Any recommendations for a reliable circuit breaker finder that won't break the bank? Not looking for least expensive. Price, within reason (under $75), is less important than convenience and reliability.
Re: OT --Reliable circuit breaker/outlet finder
I've had several and they worked fine on some panels but for some reason do not work on the panel in my house. Based on that, if you buy one, maybe make sure you can return it if it doesn't with your panel. Maybe you'll have no problem and it will work fine.
But any single-person method would still require a lot of walking back and forth. Can you hire a kid to help for an hour? When doing this we use a pair of walkie talkies to communicate but I suppose a cell phone would work too.
This may work, toner *LINK*
Keith Newton
With all the circuits turned off for the whole house, you could go room to room plugging into the outlets while someone else was back at the panel bringing the little detector up to the black wires as they enter the breakers until the correct one is detected. The sender emits a little radio signal from whatever wire it’s on. The main panel person fills out the info on the door.
For lights, I guess you would need to remove the switch cover to get to the hot / black wire.
https://www.amazon.com/Tracer-Circuit-Tester-Alligator-PTE/dp/B00ADHQCIO/ref=mp_s_a_1_1_sspa?dchild=1&keywords=Wire+Tracer+Electrical&qid=1601417749&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFDSFhZWERVS0ZVVE8mZW5jcnlwdGVkSWQ9QTAwNTI5MTcyMTlXT
Funny you mention a "helper".
Gary Smyth
Tried to find a high schooler - male or female. All they had to do was flip the breaker and i'd tell them my location. Aside from quarantine, the two local kids I got a response from were afraid to touch the panel without turning off the master. Doesn't anyone ask their kids to help at home? Disappointed, but not the kids fault.
I did a lot of electrical work in my younger days - before the advent of circuit tracers I could afford. I always used a loud vacuum sweeper to trace the circuits. Turn off all the breakers, plug the vacuum in and listen, when you hear it turn it off again to be sure. Turn it back on and then then plug it into each outlet in the same area to identify live outlets. This is done to insure there are not two circuits in the room (like living room - kitchen etc.) It always worked well for me.
Ralph Lipeles
Don't be too concerned about the price. After using it you can sell it and get most of your money back. I would guess that eBay has a bunch of new and used ones.
John McGaw
I have an elderly Sperry device(s) which works quite well. They still sell similar units although mine is so outdated that the exact item seems to no longer. Amazon has several similar types.
Re: OT --Reliable circuit breaker/outlet finder *LINK*
Lee Schierer in McKean, PA
I have a Klein Tools ET300 and it works very well. I have used it on industrial and home panes, by Square D, GE and Pushmatic. It requires the circuit to be powered. You plug the transmitter into the receptacle or light socket (using a screw in adapter), then at the panel you scan the entire panel once with the receiver ignoring any beeps, then go over the panel a second time to locate the correct breaker to turn off. At $29.99 it is pretty cheap.
Lee
Klein Tools ET300
Garthfromsandiego
Knew a guy that did the same thing with a radio. Turned volume up high so he could hear it at the breaker box. None of the breakers silenced the radio! Turns out that the radio had an internal battery. Best intentions...
Visit our sponsors *LINK*
I just bought a circuit tracer from Lee Valley a while back. Works great.
Lee Valley Circuit Breaker Tester
Re: Visit our sponsors
Just curious. Those I have came with an adapter, a light bulb base that screws into a socket to check lighting circuits. Did the one from Lee Valley come with a way to check light circuits or just those with 110v receptacles? If not, I guess one of those light socket adapters with a receptacle would work.
I never had occasion to check light circuits, John, but the LV unit didn't come with any accessories. I guess you'd have to cobble up some kind of pigtail.
johnv
cheap, quick and easy
2nd
David Yoho
Yep, that's the one I got too.
Ha, "No longer available"!
Thanks to all
GarySmyth
Went with a new Klein. Under $40 w shipping. Will let you know if it doesn't work as intended.
