My CBN Wheel arrived.....
And I installed it on my ancient Rockwell 6" grinder. Not without some difficulty. I had a 3/4" wheel on it. The new wheel is 1" and the old washers were too thick and there was a roll pin in the shaft. Could not get the pin out so I drilled it away to nothing and used conventional washers for padding. Took some fiddling and searching, but it got done.
I moved the old white wheel to the other end of the machine. I also dressed it.
There were a set of planer knives that needed sharpening because they discovered a nail. The grinder has a jig meant for plane blades and chisels, but it has been adapted for planer knives. I sharpened them in a matter of minutes. Then stroked them on a 600 grit diamond plate and then stropped them on a 1 X 30 sander with a leather belt impregnated with diamond.
I won't say they were sharp, but I looked and had blood all over them. Cut myself and didn't even know it.
Two things surprised me. One, the wheel is steel and heavier than I imagined. The first time I turned on and off, the grinder ran for so long I thought the switch had failed in the ON position. Took it 4 1/2 minutes to stop. I guess those old bearings are still fine.
Two, the wheel is 180 grit and it produced more heat than I expected. This was the first time for the blades on the wheel and were probably getting a little more shaping than next time.
So far, pretty happy.
Re: My CBN Wheel arrived.....
Barry, a couple of points:
1. Yes, the wheels run and run when the motor is switched off. Mine run for 8 minutes (2 wheels, so more weight and momentum). Just shows how well balanced the CBN wheels are.
2. You can generate heat ... with a heavy hand. Lighten your touch. The wheels are a large heat sink, so they will run much, much cooler for the same touch on a white wheel. Don't assume that CBN is a free lunch when it comes to heat.
3. The wheels need a little time to run in. Then they are smoother, but still as quick as ever.
John Jardin
Derek,
You show a flat attatchment table on the "Tormek" fixture where you can grind the concave bevel on thick scrapers. Is this "table" something that you made or is it a Tormek accessory?
I bet yours are 8" wheels....? With too of those it would run a long time.
Mine is 6". I was surprised at the weight. Somehow I thought it was going to be aluminum.
Thanks for the reminder it is going to run in, that will be better. It produce a wire edge that was more ragged than I expected, but I bet it will get better.
Now on to the unicorn edge.
John Jardin
Scratch that!
I found the Tool Rest SVD-110 in the Tormek manual.
Reminds me of the saying "seek and thou shalt find"
John Jardin
Barry,
Who did you buy the CBN wheel from?
Lee Valley....They have 6" by 1" wheels in several Grits for $99 with free shipping. They did add VA sales tax to mine, driving the price to about $105.
Very nice setup for a 1/2" shaft. Runs very true.
