Laminate Question
Doug Reynolds
I know when veneering one should veneer both sides of the substrate/panel but, what about applying "plastic laminate" to just one side with contact cement? Can it be done without worry that it will significantly warp or cup?
I am making two chuck boxes (camping kitchens) out of Baltic birch plywood 1/2" thick. The front panel folds down and becomes a work space. I would like to laminate it instead of just applying finish.
Thanks in advance for your suggestions, Doug
