Completely OT, Plumbing troubles
My friend owns a house about 15 years and has CPVC supply piping and an irrigation system with PVC pipe.
Last week he asked to borrow a plane because one of his doors started dragging on the floor.
Later he heard water dripping, perhaps in the crawl space and decided it was the condensate line from his AC. He crawled under the floor to check it out and found a hot water plumbing leak just in time to mess up his planned week at the beach. We discussed it and he shut the water off and set up a plumber for a emergency return trip on Wednesday.
I met with him on Wednesday but the plumber did not show. So we went to Lowe's, bought the supply's and made the repair ourselves. Cut out a complicated connection involving a tee and reducers and two different sizes of pipe. We were laying in puddles of water on top of his plastic vapor barrier. Got soaked to the hide. In the process I spilled about a tablespoon full of Glue on top of the plastic vapor barrier. By this time it was almost 7pm and he wanted to return to the beach. So we left the water turned off and he left. (You need to wait 6 hours for the glue to cure for hot water.)
Next day his neighbor calls and tells him water is running out form under his house. How could this be? We left the water off at the main shutoff valve. Could be his incoming water line failed or, he could have an irrigation leak because that has a separate meter and supply. I raced over to his house and turned off both meters.
Today he returns and I meet him at his house. He goes underneath and I turn the water back on at the meter. Excellent, out repairs hold, no leaks. Turn on the irrigation and it leaks dramatically. Turns out that after we left that little puddle of glue drooled off the edge of the vapor barrier and landed on the thin wall irrigation supply pipe and melted it. About a 1/4" hole. Back to Lowe's for more parts and a new repair.
We were standing in his garage cleaning up and marveling at how amazing it was that in a thousand SF crawl space that little dab of glue managed to find that one pipe. At that moment his wife opened the door and was shrieking (She does That) about water running out of the washing machine. Apparently the fill valve on the machine is worn and failed to seat completely and the machine accumulated way too much water while they were out of town. My friend said he is never going on vacation again.
And, for a wood working angle to justify posting this even as an OT, The door dragging on the floor was what we Home Inspectors call a Clue. The wetness under the floor was causing things to swell.
You gots to love plumbing repairs.
