A55 Smoothing Plane
Hot glue/clamping bock question
I was assembling a mitered joint to create a flared leg. The joint had four dominoes in it. I tried hot gluing a piece of wood about 5/8" square and two inches long onto both pieces of each piece with the idea of applying clamps across the joint to pull it together. Didn't work. At least one glue block failed at each side of each leg. I was using spring clamps. Fortunately, bar clamps did work, but it was frantic for a few minutes.
So, I think I did it wrong. I should have had the glue blocks on the edge of the leg and rail, cut to an angle to let the clamp get a grip, I think?
The second part of the question is what to use for hot glue. I read some of it is for Arts and Crafts and some has industrial applications. I used whatever was in the gun and applied it and clamped it in place. So, Does anyone get good use out of hot glue and what type do you use?
Re: Hot glue/clamping bock question
for this application I use regular glue with a layer of news print between.
Maybe it's time for you to get this, *LINK*
Keith Newton
I have no experience with it, but if I needed it like you, what's a mere $100 bill anyway?
https://www.woodcraft.com/products/infinity-pur-adhesive-applicator
Re: Maybe it's time for you to get this,
I was In at a hundred, but for $109.99 I am out. Way too much.
Dohh!
I have probably done that fifty times. Shouldn't mess with success.
I think I need some of that Previgen stuff, because we all know what good memories jelly fish have.
John McGaw
I did the hot glue thing exactly one time. I discovered from my experiment that some hot glues applied to some woods get into the grain and totally flummox later finishing. There may be combinations where it will work but I never had the nerve to go back and try so now when clamping I just sort of stumble my way through.
Painters tape
Clifton C
When hot gluing blocks to solid surface (like Corian) or other nonporous items I glue directly, when hot glueing glue blocks to porous surfaces, I put down a layer of painters tape first. When done, the glue block on the painters tape pull off with a little force. To get hot melt off nonporous surface, squirt with alcohol. The alcohol doesn't dissolve the hot melt, so no messy sludge, it just breaks the bond and the glue peels right off.
