More uses for blue tape
Keeping leg orientations error-free can be a challenge. As one pokes ever more holes in a leg to receive mortises and dovetails the risk of getting one on the wrong side increases. Derek's use of blue tape has been inspirational, and I didn't realize how cheap it is.
(can someone explain why this picture posts upside down. And when i rotate it before posting it posts 90 degrees no matter how I store it. Well, lean over 90 degrees to see it correctly)
One can see from this frame that the front legs have several mortises and a dovetail at the top. Because of the way the bottom stretcher is located to accommodate a shelf it was going to be easy to locate it incorrectly. Copying what Derek does for dovetails I pasted a 2" wide piece of blue tape on the leg and marked the mortise out on the tape. After all the legs were taped and marked I brought the legs together as they would be oriented in the table. Confirming the mortises were marked correctly I proceeded to bore them.
