Edge Banding Plywood Cabinet Fronts
Will Blair
My wife very much likes the look of light, plywood cabinet fronts to replace our old kitchen cabinets.
I'm a intermediate woodworker. Better than a hack, definitely not a pro. But I think I can do it myself, using existing hinges / hardware which are in fine enough shape. I'm just going to literally trace existing cabinets to get the exact sizing, and sink hinge holes where they previously existed using a forester bit.
I think I'm using Baltic Birch for strength, lack of warping, overall look.
If I'm using 3/4" Ply - why is almost ALL of the Birch veneer ( iron on ) edge banding 13/16"s wide? The most common application for this veneer is to edge plywood - why is it hard to find 3/4"?? ( which is just slightly less wide than 13"/16")
Is the idea that the ACTUAL width of the veneer is a little closer to 3/4" - OR - does it shrink a little? OR - is a slight overhang / overlapping preferred to create a better seal, so to speak?
RELATED: Main reason I am considering edging with veneer isn't aesthetics - we don't mind seeing the ply layers when you open the cabinet. ( You won't see it when closed.) Mainly we want to avoid any steam from the sink / dishwasher slowly getting into the layers of ply. Is there any other method to better SEAL the edge from any moisture? Would ripping thicker strips of hardwood (like 1/8" birch) and creating a much thicker edge band better protect the plywood?
Any other ideas? Or would a solid Poly U finish do all the sealing we need?
THANKS!
-Will
