Refinishing counter in a Cafe
Tara Desmond
Hello all!
I am refinishing countertops in a cafe and was looking for recommendations for a product to use. It is currently black paint. There is usually a pastries box on top that has scratched it up. they are looking for something durable and easy to clean.
Any recommendations with relatively low dry times?
Thank you!!!
p.s. I really appreciate this forum, and how passionate and prompt everyone always is with replies. this is month 2 of being self-employed as a finisher and I'm so happy to have people here to help out!!
Re: Refinishing counter in a Cafe
Keith Newton
Looks like a good place for plastic laminate, or corian, with maybe a cutting board thrown in.
For commercial work.....
Nothing beats conversion varnish. Must be sprayed. Available anywhere commercial finishes are sold- Sherwin William, Klingspor, etc.
for brushing- Urethane floor varnish
I'll second that suggestion
Also, probably can get a cut-off from the rock counter top people that would do nicely and not cost much.
Re: I'll second that suggestion
I agree with the folks above. My first impulse was "That's a place for plastic laminate." But I also like the Corian idea. And a nice piece of stone or quart would do nicely as well. The quart product does not need to be sealed like most of the stone.
Be careful trying to glue laminate over the existing top in case the glue/contact cement is not compatible with the existing paint.
walta
A also think the old top was a laminate top (Formica)
Both Formica and Corian are out of style today and look dated unless you are going for a vintage look in that case the wear is an asset.
I do not think any paint or varnish will stick well enough to the old Formica to stand up to commercial wear.
If you like the current look have the old Formica removed and replaced.
I would look at getting a new quartz top made. I think granite is on its way out of fashion.
Walta
The thing about stone,
Keith Newton
Is that as you can see, someone has been using this surface as a cutting board. They may just be cutting lemons for tea, but it's hard to break people of their bad habits, and on stone, soon their knives will be too dull to cut up the lemons, so they will borrow others from the kitchen and soon all the knives are dull. I don't think the Corian type material will dull the knives.
At my cabin I have a favorite knife that I use for butchering, and try to always keep it sharp. A few weeks back I had visitors down. While we were all in the kitchen doing some part of preparation, I heard a klink klink sound behind me. When I turned around I caught the guilty person that had been dulling my knife down to butter-knife level. She was cutting a squash up on a dinner plate with MY knife. While I tried not to be too harsh, I'm pretty sure she knows that isn't ok.
Don Stephan
While some sort or stone or possibly laminate might be a good solution, the original poster {OP) is in the 2nd month of a new career as a finisher. Some sort of stone might be the ideal solution, but some discussion might help further the new career. During this ongoing pandemic, I admire anyone willing to strike out on a new career.
Can you advise in more detail how the worn areas were so badly worn, and what the current countertop and surface are?
Clint Searl
Clint Searl
Think about flashing copper or galvanized steel sheet wrapped around the top. D Durable and looks funky cool.
Re: The thing about stone,
good point. Need to have a cutting board as art of the station.
She cut on a plate with a good knife!!! >(
Had the knife been Unicorned.....
Its robust edge would have survived better.
Re: Had the knife been Unicorned.....
Keith Newton
No, it just had a fine bevel on both sides. I bought a little drill buffer today to take down there though, so I'm going to try it on that knife.
be cautious with knives. If the tip catches they can deflect unsafely.
Kneale Brownson
If it's black paint, get a polyurethane paint.
kneale brownson
Stuff is almost plastic and very durable. Put protective pads on the pastries box.
Re: If it's black paint, get a polyurethane paint.
Pete in Holland MI
Something to consider.......
Nearly all coatings (paint, varnish, etc) will need several days to cure hard, a luxury of time the shop may not have. Installation of laminate or man made counter top could be done in a few hours, and be ready to use after you walk out.
