Dewalt Benchtop Planer
John Foster
My old Delta benchtop planer died, and I am looking for a replacement. The Dewalts seem to be the preferred choice. For the amount I use it, the 734 is probably adequate, has anyone ever purchased a 734 and afterwards wished they had purchased a 735?
There are older American made Deltas , Canadian made Generals and some smaller SCMs out there, if they are in poor shape the price is not bad, but they would need a lot of work; if they are in good shape people want a ton of money for them.
I sort of see the Dewalts as the missing link between throwaway machines and the better cast iron commercial ones. Agree, disagree, should I be looking at other brands
? I also sometimes think that my Delta which was the bottom of their line when I bought it lasted 17 years, if I got that out of another low cost unit I would be happy too.
Thanks
John
Re: Dewalt Benchtop Planer
Dick Coers
Any decision of thickness planer purchase has to consider volume of work. If you run 75 bd feet or more at a time, cast iron for sure. Run 5-6 boards at a time, bench top for sure. Buy your lumber rough sawn, consider cast iron. But hardwood at a hit or miss surfacing, bench top works. All based on amount of running time amounts of material to be removed.
Jack Guzman from Maine
I have the 735 and I love it. I picked it over the 734 because I need a full 13" for the kind of work I do. I buy rough wood and do my own thicknessing. I also like the chip ejection blower.
I have an older one with knives I can sharpen myself, a Dewalt 733 I believe. Had it about 20 years and like it well enough. Replaced the bearing blocks once. It won't take over a 1/16" so starting from rough stock can be tedious. I have thousands of feet of rough stock. Does a nice job once you get past that.
I also have a brand X 15" that somebody sold me for $300 I have refurbished. Works well enough, but I am thinking of up grading to a Grizzly 20" with helical head.
I would buy the Dewalt without hesitation if mine wore out or failed.
I have had a DW735 for many years. I don't regret buying it.
I have had to replace the dust shroud twice as it is plastic and the amount of lumber I planed wore it down.
If I had to do it over again, I probably would get another - or look for a used 15".
The problem w/ getting a 15" is that it isn't portable at all. I built a roll around cart for my DW735 - so I can "flip" the planer down into the cart and roll the cart under my table saw extension when not in use.
Bruce, a MN Galoot
Lukewarm for me. I have a 735 and while it does a nice job, you need to know that the Dewalt blades are crap. They just don’t hold an edge. The blades are not adjustable and can only be sharpened a couple times before you will need to replace them. I get my blades from Holbren. They’re better than Dewalt but still not adjustable. If I had the money, I’d spring for the Byrd Shelix.
Christopher Fitch Memphis
"The Dewalts seem to be the preferred choice. For the amount I use it, the 734 is probably adequate, has anyone ever purchased a 734 and afterwards wished they had purchased a 735? "
I have a 734 and I wish I had bought the 735 - especially since when I bought the 734, the 735 was on its intro pricing and was cheaper that it is now.
That said, the 734 works fine.
735 is upgradable
ronster
I immediately installed a shelix on mine, and ebayed the unused original head with blades. Good move for me a couple of years back. Definitely no regrets.
Re: 735 is upgradable
Bill White
Well.......I'm still using my 733 that is 15+ years old. Darned thing won't die.
johannaj
johannaj
I had a 20 inch Woodtek planer. I sold it and bought a DeWalt 735. That huge planer took up too much space and I decided that I really did not need that much planing width. The DeWalt serves me very well since I do have a large dust collector that I connect to it.
On the other hand, I wish I had a larger jointer (mine is 8 inches), but I doubt there is enough room for it. When I need to joint a wide board, I take it up to Santa Fe Community College and use the 20 inch jointer there.
Once I complete the two dressers I am currently building, I don't think I will build any more large pieces. Maybe a dining table, though. It's just getting too hard to lift big pieces.
