Hand Plane metal repair questions
Many posts abut fettling planes, thanks for all the help.
Two current questions....
On one of the block planes the sole was badly cast. One rear corner of the sole it way high. And area the size of a thumb nail or more and maybe rolled up a 1/16", It would require removing so much metal it might weaken the sole to the point of ruining it. Is there an alternative? Leave it alone? Does not seem it would reduce the functionality. Cover the area with JB Weld and flatten that? Ideas?
On a Stanley 60 1/2 block plane, the throat is adjustable. My "throat adjusting lever" is a crescent slot with a handle and a pivot pin. The pin is missing. It would be a rod about 3/16" or maybe a 1/2" long and about 1/16" in diameter. I could scrounge up a piece of metal, a nail or the shank of a drill bit. The question is how to fasten it? It's going to be under some lateral stress. Peen it? JB Weld? (heretic) What?
Re: Hand Plane metal repair questions
Bruce, a MN Galoot
A rear corner of a block plane doesn’t mean much, actually, unless it’s gouging your work, leave it alone. I’m sure mine is out by that much, and it’s been doing good work for 70+ years.
As far as the pin being missing, it’s not really necessary to move the adjustable throat, so do what you want. I might JB it into place.
Thanks. Turns out the hole was near and 1/8". I found a nail that was almost perfect. Ground it down a tiny amount and ground off the point. I drove it trough the hole in the lever, which was harder to do than I expected. Cut it off and tried to peen it. It seems very secure. Good enough. If it fails I will try again.
Upon inspecting it again I decided the slope was not as bad as I thought. The part that is way off is was tiny. Back in business.
Metal plane fettling
Jim Matthews
A common approach to rehab for vintage metal planes is to lightly file the front, rear and sides in a slight relief (like a chamfer) to avoid sharp edges.
Not so much as you can see a bevel, but enough that you can't feel a distinct corner.
Re: Metal plane fettling
I have done that. Some were so sharp they would have made good scrapers and might have interfered with using them. On one or two the front end was somewhat battered and I put a tiny chamfer on them to both clean them up and to avoid digging into the work.
They are all nice and shiny, I think I need something to put on them to avoid rust.
Try camellia oil
Natural oils and alternatives
Jim Matthews
I'm with EV on this, Camellia has no odor, won't thicken and works well.
If you have WD40, regular application with a rag will do.
I keep a coffee can stuffed with an old T-shirt wetted in WD40.
A swipe on my chisels and blades keeps rust away.
