REAL MILK PAINT
Printer Ink Solvent ?
Yonak
I got one of those cheap printer ink refills and, while installing it, it leaked all over my hands. I've tried everything in my shop to get it off and nothing really worked. I tried acetone, xylene, mineral spirits, naphtha, lacquer thinner and alcohol. The alcohol worked the best but not very well. Has anyone got any other suggestions ?
My wife is now mixing up a cocktail of vinegar, baking soda, lemon juice and toothpaste, a recipe she found on YouTube ?
Well, the witch's brew worked as well as anything (that characterization is not to be taken as an editorial comment on my wife). I guess the best remedy is to wear rubber gloves next time.
I am now going to put some Bag Balm on my hands after subjecting them to all those chemicals.
Re: Printer Ink Solvent ?
I haven't tried using printer ink to dye my hands but with other things I use a hand/nail brush and scrub. Recently, I got some black urethane on my hands when installing windshield glass, even when using nitrile gloves. (I think the gloves developed holes in use.) Hand cleaner made for shop grease, denatured alcohol, and acetone didn't touch it. What worked best was a gel ethanol-based hand sanitizer scrubbed with a soft hand/fingernail brush, followed by soap and water and the same brush. Don't know if that would work for printer ink.
But if it doesn't, don't worry too much, time should remove it.
The problem
The ink is made by dispersing pigments in something. The "something" will dissolve but the pigments are highly insoluble. As Jordan said, the only way to be rid of them is scrubbing and given their color intensity even if you scrub away most you will remain colored until that layer of skin falls off.
The YouTube recipe is a testimony to the failure of high school chemistry classes to teach chemistry. Other than the abrasive in the toothpaste there is nothing in that mix that would be useful for this task, or any other I can think of. Any time someone recommends mixing an acid (vinegar and lemon juice, AKA acetic acid and citric acid) and a base (baking soda , AKA sodium bicarbonate) to make some even more effective product than either alone one can be assured the source of this suggestion failed chemistry.
Jim DeLaney, Austintown, Ohio
Re: The problem
One of the first things you learn in Chemistry class is that 'Acid plus a base yields water, plus a salt.' In other words, a generally useless substance.
Hey, it made my hands smell like lemons.
Yonak
It wasn't all bad.
Soap with Pumice particles????
Leo Cuellar
Leo Cuellar
Goof Off painters wipes, Tub O' Towels, or Scrubs in a Bucket all do a good job with dies & inks and other noxious stuff. They store for a loong time if you keep the container closed. Nut Scrub is ok too if you like the pour out stuff.
ReDuRan *LINK*
Clifton C
This stuff is the real deal... I'm sure there is stuff it won't remove, but so far, its removed everything I've gotten into.
ReDuRan
Thank you, Clifton.  I ordered some.
ReDuRan how it works
The literature says it is for removing dyes, no mention of pigments. MSDS reveals how it works. It is simply a bleach in a glycol solvent. More mild on the hands than chlorine bleach but probably not as effective. I'll be surprised if it bleaches printing ink, at least the ones for photograph prints. But let us know if it does as that will be useful knowledge.
Will do.
Stuart Johnson
I seem to always have some sort of crap (not literally) on my hands along with al the nicks, cuts and so forth. I figure I might be old but I an out last them so I just move on and don't worry. If the only reason my wife is going to leave me is because I have a purple stain with green edges on my hand instead of the other 45 years of stuff I'm in pretty good shape.
You are supposed to be socially isolating, so why do you care :) :) :)
Not so fast...
Jim Matthews
"If the only reason my wife is going to leave me is because I have a purple stain with green edges on my hand instead of the other 45 years of stuff.."
You're not getting off so easy.
SWMBO gets the last word.
That's how they win.
TomD
Hair spray was always the cure for ink stained wretches. Haven't tried it on printer ink.
Yonak
Tom, I hope that's a typo. If not, I'll bet you know some pretty good lookin' miscreants.
