Review of Minwax Acrylic finish
I have never had a satisfactory experience with a water based finish. They always look dead to me, or worse bluish, and this experience includes Target polycarbonate and urethane products. Ash is difficult to finish because any yellowing of the finish shows up ugly on the white ash. Only the water based finishes have hope of not yellowing, and in theory, acrylic should be the best.
I tried the Minwax product available at Lowes. I applied the gloss to a test board (never do chemistry experiments on the final furniture). It applied smoothly with a foam brush. There was some grain raising. Applied as a sealer it dried quickly and sanded smoothly without loading the paper. As a sealer I would rank it equivalent to blond shellac and at a lower cost. In the future I will consider it as a sealer instead of shellac.
The appearance of the gloss on the ash was as good as any lacquer, or shellac, I have used. It was to my astonishment bright and lively and brought out the figure in the wood.
On the desk I sprayed on one coat of gloss, sanded with 400 grit and top coated with satin. I was able to spray a thin coat to achieve a "close to the wood" appearance. It sprayed as easily as any finish I have used. I had no atomization problem and it laid down wet and level. It was a humid morning but I had no worries from blushing because the coating was already wet!. Spraying shellac would have been a disaster under these conditions.
I do not know its durability. I will report back in a year.
Summary- may replace shellac in my shop. Good candidate for light colored woods like maple and ash.
Re: Review of Minwax Acrylic finish
Thanks for the report. I have been skeptical of the water based finishes. I am old and set in my ways and can barely use lacquer. I will have to give this a try.
Kneale Brownson
kneale brownson
I've found poly paints and varnishes to be very durable. I've used them indoors and out for the paints, just indoors for the varnish.
Christopher Fitch Memphis
I've been using Polycrylic for years with good success on light-colored woods. I've sprayed and brushed it on with good success.
Here's a a table I used it on:
and another:
will you comment on durability
How does it compare to traditional varnish?
Re: will you comment on durability
Hank Knight
Thank you, Bill. I'm a long time shellac fan, but you have given me something to think about. Water based finishes offer some real advantages, but finding one that gives great results is hard. This may be the answer for me.
Both of those tables are with relatives
I'll ask them how they have been holding up and give some of their feedback.
Actually I already have an example
here's a picture of some of the drawers from my workbench. Bench is 15 years old so the drawer fronts have certainly seen some use and wear. It still looks fine to me.
Kneale Brownson
Re: I'd say good enough
kneale brownson
Here's a sign that hung outside our house for 20 or more years. Finished with poly paint and a poly spar varnish.
I had to cut the bottom off the post and reinstall it after the cedar rotted in the ground.
The color
Yonak
I finished an ash project with Polycrylic a few years ago and I found it turned the color of the ash sort of greenish blue. It wasn't a problem with my project because the walls around it are kind of green and it fits. ..But it could be problematic if the near environment isn't kind.
Yikes !  Say that three times.
greenly finished ash
When I bought either polycarbonate or polyurethane from Target they warned that some ash would turn green. They sold a sealer to prevent. Must be something in some ash that reacts. I wonder if the green would fade quickly in a sunny room?
In any case my ash stayed white.
It's sort of okay. I have it on my kitchen cabinets as I refinished them in place - so I didn't want a polyurethane smell in the house.
For wear surfaces like the pots and pans cabinet - it didn't hold up that well.
For plates and glass cabinet - it's doing okay.
The outside of the cabinets look good.
