Construction Adhesive
Stuart Johnson
Life was easier when all the big box stores had was Liquid Nails. It seems like there must be 100 different brands or types. I will be using it to glue pressure treated 2x10 on top of concrete block. What adhesive do you recommend?
Re: Construction Adhesive
johnv
Liquid nails makes an outdoor adhesive for just this application. Heck even Gorilla Glue makes one for this.
Kevin French
I just bought a tube of the Liquid nails outdoor adhesive for some masonry blocks. The tube I bought is called FUSE IT
When I was building I used a ton of PL400. PL500 is for landscape and available at Home Depot. I would look at that. It used to be made by BF Goodrich but now it's by Locktite, but that could be the same company.
