Bandsaw blade question
I bought an old Hitachi B 600 bandsaw and then bought a new blade for it. The blade is 3" wide and I believe it has just over one tooth per inch. Even when the blade was brand new I was not impressed with the smoothness of the cut. It rips like magic. You can shove 3" thick walnut through it as fast as you dare. That part is really nice.
The part that bothers me is the blade leaves vertical stripes on the surface. It seems to leave regularly spaced lines/ridges. The spacing depends on the speed you feed the wood. Between a quarter and half inch apart. I have sawed probably about a hundred linear feet of wood on it and have not hit any metal.
So, what to look for? Is there one tooth bent or not set properly? Is it possible to tune this blade? I was hoping to get cuts good enough to cut some veneer.
