Have a question? Ask Woody!
Doors for console questions
Getting back to working of the console for my son. 7' long about 2' tall or less, maybe 22" with the typical splayed legs. It will have a bay of drawers and two sliding doors. If all goes to plan the doors will be about 30" wide and 20" tall out of quarter sawn white oak. The picture he showed me had teak doors with the grain running vertical.
I am concerned that if I glue up the doors with the grain running vertical they may not remain flat over time and bind in the grooves and not slide well. I have a vacuum bag and could veneer the doors onto Baltic birch plywood.
It occurred to me while typing the questions I could orient the grain horizontally and it would me much more likely to remain straight along the edge. If I can find four or five pieces seven feet long I could use them for drawer fronts and doors and make the grain continuous across the front. Hmmm.
Any thoughts?
Re: Doors for console questions
Yonak
Barry, tell a little about the construction of the doors. How thick will they be ? Are they just a single piece of wood per door or frame and panel construction ?
Neither option is good
Doors that size made from just glued-up boards are going to be at the very least unpredictable. They might stay flat if you're willing to use only quartersawn material and to make sure the MC is equalized throughout, but I wouldn't do it that way.
I can understand that you don't want the look of frame and panel. I personally would probably veneer them, but if you use solid wood, I would make them some variation of breadboard construction, maybe just stiffeners across the ends.
Hank Knight
Barry, I posted an idea on the Hand Tools board several weeks ago that is a different take on frame and panel. It might work for you. In my post all of the slats in the panel run horizontally, but there is no reason they couldn't run vertically. See here:
http://www.woodcentral.com/woodworking/forum/handtools.pl/page/4/md/read/id/493526/sbj/side-panels-an-idea-for-you/
