Discontinued Multi Axis Milling System?
Don Stephan
A couple years ago I was given a Woodchuck Milti-Axis Milling System Model MA12 and I'd like to try to use it. After turning a spindle on the lathe, it is mounted on the axis of this equipment, with a router and bit on a tray above. Manually turn a handle and different gear combinations move the router along the spindle as it is rotated, to create rope twist, barley twist, and maybe other effects.
An Internet search has not found anything so perhaps the manufacturer Pahtiom Engineering in Provo Utah has ceased operation.
Does anyone have any experience with this equipment?
Without appropriate router bits I can't even experiment.
Re: Discontinued Multi Axis Milling System?
John in NM
The few pictures I found look a bit like the Legacy Ornamental Mill. You could try asking them about it, they may have taken over the patent or something.
Bits for the Legacy machines are available from Magnate Carbide.
Steve jenkins
It is the legacy. When it originally came out it was called the Woodchuck
Keith Newton
Hey Don, When you get this up and running, I may have a job for you if your willing, you can contact me and I’ll give you the details.
