First time steam bend troubleshoot
Tom G
Hi. I have been building stuff out of wood for 20ish years, and last night I decided to finally take a plunge into steambending. The strip did not get as flexible as I expected. In fact it hardly bent at all without a good bit of hand held pressure. Could someone tell me what I am doing wrong (to avoid a whole bunch of trial and error). The strip I tried to bend was ash--an 8 inch strip about 60" long. Bend was ~5 inches. My box is 72" x 4" x 2" internal dimensions. I got the box up to 200 deg (thanks to the wife for use of the meat thermometer). Could not get it any hotter. Once at this temp, I let the strip steam for 7-8 minutes (per the steam generator mfr instructions). I put the inlet for the steam hose in the middle of the box since it is the middle of the strip I am trying to bend the radius into. (I know its generally recommended to put the inlet at one end). The strip was elevated with some dowels to allow steam to circulate all around it. I was using this product to heat the water. (Note the hose is 12 ft long) https://www.woodcraft.com/products/earlex-steam-generator-for-bending-wood
I can think of a lot of causes for my lack of success, including box volume too big/not hot enough, improper inlet placement, hose too long, insufficient steam time, stock too thick, too much time to get stock into the clamps. I am pretty sure the grain in the stock was ok.
I appreciate the help.
