200+ woodworking book reviews
How to sharpen a Forstner bit
My 1" is too dull to be useful. Unsure how to grind the rim bevel.
Re: How to sharpen a Forstner bit
There msut be about ten things sold as Forstner bits.
On the cheap ones I have that are coat with "Tin" I sharpened the inclined cutting plane that cuts the bottom of the hole with a diamond file. Mine have "saw teeth" that cut the perimeter and I touched them up with a diamond file also.
As for the cookie cutter rim....?....Maybe a Dremel with a conical diamond hone.
Clint Searl
They're consumables; buy a new one
John McGaw
I've touched them up with a diamond hone and with fine abrasive paper. Neither seemed to help that much or for long so they eventually get replaced.
Bruce, a MN Galoot
Barry sez “As for the cookie cutter rim....?....Maybe a Dremel with a conical diamond hone.“
That’s what I do. It works pretty well.
John in NM
I use a Dremel or Foredom tool with a little grinding stone for the rim. Even one of those sanding drums will do.
The rim is less crucial than the bevels, just needs to be sharp enough to make a clean side without burning. Main thing is filing the bevels nice and sharp. Other main thing is keeping the bevels even :D Don't want one cutting heavier than the other. Counting file strokes is enough to keep them even though.
A triangular file can't quite get all the way in next to the spur, so I do that with the Foredom too.
William Duffield
I agree with Clint, but with some additional details. I started with the cheapest set of Chinese Forstner bits I could find. If I've used one enough to dull it, I go out and buy a Famag Bormax bit to replace it. I've never worn one of those out, not even my dog hole bit. :D If someone does a lot of kitchen cabinets with Euro hinges (I know you don't), then I would start with a carbide tipped 35 mm Forstner bit for that application.
Rick W
My local sharpening service does a good job of sharpening them. I think it costs either $5.00 or $ 7.00 each. That's enough so I only sharpen the good ones, and I discard the cheap ones when they get dull.
Rick W
