OT: Lawn sprinklers
OT: Lawn sprinklers
Kneale Brownson
OT:  Lawn sprinklers
kneale brownson
The hole in this sprinkler head lets out a steady stream. Don't know what was in the hole previously or where it went. Anyone know what I can plug it up with?
The tube on the left goes to another sprinkler.
Re: OT: Lawn sprinklers
Garthinsandiego
It had a fourth elbow connector. Will have to replace the the whole assembly, unless you have others that you can scavenge parts from.
Keith Newton
You can buy a NTP tap then cut new threads, and screw a plug into it.
Kneale Brownson
Sounds like a winner, Keith!!!
Ralph Lipeles
If the manufacturer's name is on any of the pieces you can track them down and maybe get what you need.
Also, the line probably goes to a section of sprinklers. You probably want to get it reconnected rather then plugging which will cut off water to a section.
