American Beech Bad Behavior
David Weaver
Since I want to woodwork more than I want to make doors for 4 hours a day, I figured I'd make a couple of planes to keep the flow going.
American Beech.
I've had this wood for about 4 years as I can recall, maybe 3. When it was fresh (KD), it was a challenge dead of winter here any time the temp got close to zero, but I sealed the ends and when side checks formed (that's right, you can expect unfinished and some finished dried lumber to get side checks in the winter even if it's thoroughly dried).
So, I resawed a blank that had a pretty unusual smiley-face check (Followed the growth rings), figuring I'd see how deep it went (it didn't show on the other end). Can only be a few inches, right?
Nope - end to end.
Bottom and top both looked like this with a bunch of the center just falling out loose. I was just able to get a jack plane billet out of the top (right at the limit after removing the filth).
Great.
Pretty ....dead quartered (which you can't really see, but just dead quartered).
Start the mortise.
"Feelarn!", as we used to say in college. I guess I"ll keep this plane.
(look in the front of the mortise if you can't see it).
Now, it's possible that the check in the front of the mortise is honeycombing and it could've been there the entire time.
I find more unwanted surprises in beech than anything else by a mile.
This is wood that was sawn and dried by horizon, too - expensive, and hardly a bunch of amateurs.
Re: American Beech Bad Behavior
solutions
If I was in the plane business I would try buying beech of the proper thickness, cutting it into plane sized pieces and then steaming the beegeesus out of it. then drying. Commercially, the solution is probably vacuum drying. A local place that sells turning squares dries all their large squares, like 3 and 4"
Re: solutions
David Weaver
fortunately, I think my jones for building planes is waning and it'll happen seldom enough in the future that I'll make them out of something interesting, like the semi-common rosewood billets that show up on ebay.
I do have about 6 36" long 4x4 quartered billets of european beech that are steamed (horizon gave up trying to dry fagus grandifolia at least temporarily and just purchased european beech to market to planemakers).
They'll see me through the duration, but I like the look and feel of american beech a little better.
Best plan I can think of (I know horizon was experimenting with steaming and may have steamed these billets before drying them) with these should they show up on the market again is to get them and make planes of them quickly as they do fare better if they're waxed and oiled on all surfaces (no surprise) and monitored by a user. Even then, I've had them side check if they sit unattended.
My understanding also is that the drying schedule for 16/4 beech is extremely long and slow and it ties up the kiln, and I've gotten beech that was honeycombed (And they've thrown out lots that are honeycombed). It's just a tough wood to work with commercially for anything other than utility wood, I guess (and there's no real market for it).
I've gotten a few green billets off of ebay ,too, and it's the same kind of faffing around. I ended up just waxing them from end to end as they side checked while drying. If I wanted to keep building planes, I'd go through it faster, but there's nowhere for the planes to go really and excess guitars find a much more organized market.
Keith Newton
The separation along the annual ring isn’t a drying defect. It’s known as Ring Shake, and happen in the living tree, and it is fairly normal for there to be a radial shake on the side opposite the pith as well.
David Weaver
Thanks, Keith - I haven't looked much at pre-drying defects before and assumed that because it got worse since initially cutting another billet off of that large blank that it was separating due to seasonal movement.
It almost didn't have any consequence (well, it didn't - but the internal check that looks like honeycombing terminated this billet for now). I have gotten fresh beech billets (freshly dried) that were honeycombed, though, too, and assumed the likely cause was trying to rush the schedule to free the kiln.
