Card scraper application
I have not historically had success with card scrapers. A demonstration by Paul Hamler changed my success. Shown is the 3rd time I rolled a new edge on this scraper with only a cleaning step preceding straightening and re-rolling the burr, a task that took seconds. The burr is both effective and long lasting. Paul's technique can be found on his web site in a too long video on scrapers.
Shown are what will become two end panels for the side of a desk. The wood is ash crotch harvested from dead ash on our farm. The first picture is the panel as it came out of the vacuum bag. The second is after some scraping. Planing this piece is beyond my pay scale, so I fell back to reliable scraping.
Re: Card scraper application
David Weaver
I find that stuff to actually be easier planing than scraping. Often the stuff that's absolutely rotten planing (like very ribboned very lightweight khaya) is also terrible scraping - no strength in the ribboning and it ends up fuzzy with a scraper.
You can experiment with various sizes of burrs and try to finish off a surface like that with a dull burr or a very thin scraper, but it can also end up being a time soak experimenting.
The very first scraper video I watched and experimented with showed filing the scraper, using an upright jig and then honing the scraper bottom and a face on three different stones. It really turned me off. I got a burr, but didn't understand controlling the factors of it right away. Using only a washita stone after a file solved that (it does all of the cutting and polishing just fine by itself, and burnishing the edge does anything left over), but the deburring wheel and buffer has made it now so that I don't fight to extract life out of a scraper that's not there.
like I said....
....still beyond my pay grade. However, when you come south to preach the word of hand planing you can show me. While the center with the bold grain runs predictably one way or the other (reversed in this book match) the grain on the edges changes direction unpredictable. I can feel it with the card scraper and adjust. Some is straight up. Someone experienced with a plane may do the same kind of adjusting but I think a plane blade would bridge sever of these changes. It is veneer. A tear-out would be fatal.
In furniture building there are times when no risk is acceptable. This is priceless veneer (AKA the only pieces I have with this pattern). Of course where one's risk lies depends on experience. Mine is struggling out of novice rank.
Re: like I said....
David Weaver
Ahh...i viewed the picture and mistook it for being thicker than it actually is. Yes on the chance that you can break edges off planing (or scraping - it'd be risky to use something like a #80 near the edges).
I've planed plywood without issue (I did scrape some of the veneer off edges, but that's because I don't use an 80 much and was experimenting).
AS people would've told me on the guitar forum before i headed for saner grounds "just get a drum sander, you can't tell people to scrape or plane that - it's not realistic!"
