Favored paint stripper and tools?
I have four cabinet doors to strip. I bought some non methylene chloride stripper and I have some plastic scrapers and a small plastic brush. Sigh. It is not the fastest.
Thoughts? Or should I just be patient?
Re: Favored paint stripper and tools?
Have you tried heat?
John in NM
Works really well. I've only used one that is a heating element with a handled, but a heat gun might work as well.
Clint Searl
Clint Searl
The citrus flavored stripper works well.
Re: Have you tried heat?
There is a layer of polyurethane (I believe) under the paint.
I haven’t tried heat as I am doing it in the garage and I haven’t run a cord there yet. I can try heat next week.
There is a reason methylene chloride stripper was invented. Add it, a cheap nylon paint brush, and some very coarse steel wool to your tools and materials....and some gloves that reach up your arm a ways. The kind sold in grocery for dish washing work well.
Ralph Lipeles
If there are any nooks and crannies I find a brass brush to be very helpful. The ones that I use have a thin flat wood handle about 1 1/4" wide and 8" long. The first 2 1/2" have short brass brissels.
Dave Bair
Doesn't methylene chloride mimic carbon monoxide if the fumes are inhaled?
no
Carbon Monoxide binds to hemoglobin and blocks oxygen transfer. I don't know what methylene chloride does, if anything, but it is not the acute breathing hazard of carbon monoxide.
It is a controversial chemical. There were controversial health claims made. I don't know the current situation. It was used by the tank car in industrial processes. It is a powerful solvent for many plastics and efficient extraction solvent, caffeine out of coffee beans for example.
It is a suffocant - it displaces oxygen. It is also carcinogenic.
David Yoho
When I was doing a lot of refinishing work that's all I used. I used BIX but haven't seen it in a while. The darned stuff worked. I always did my stripping outside and on the rare occasion I had to work inside I set up plenty of ventilation.
It is a suffocant - it displaces oxygen. So does anything if you work in a closet.
It is also carcinogenic. Last I knew it was suspected not proven. But this situation may have changed.
Just looked up MSDS "Potential cancer hazard"
I must say the MSDS warnings are noteworthy. The practical hazard in a well ventilated space is irritation. When I used it daily I eschewed the wedding band. It boils at body temperature so if it gets on your hand it evaporates instantly and harmlessly gone. But if it gets under a ring or in a leaky glove...irritation that lasts a while. I preferred to not use gloves with it.
