Looking for a particular screw/bolt
Johanna Johanson
I bought a couple of small ring pulls. The machine screws for them are an inch long - too long for the 1/2 inch drawer fronts. I sawed off a quarter of an inch with a hack saw and smoothed the end with a file. I have done two so far and will need to do six more for the little chests I am currently building. I really like those little chests and will probably make more in the future. Accordingly, I tried to find shorter screws with the same diameter (they are #4s) and thread count but was unsuccessful. I thought McFeely's would surely have something I could use, but no luck there. I tried googling - no one seems to make the size I want. Bummer. Guess I'll keep sawing them off unless someone has a lead on a place where I can obtain them.
Re: Looking for a particular screw/bolt
Ray Newman
Do a search on McMaster-Carr for "machine screws". https://www.mcmaster.com/
McMaster-Carr shows two thread sizes for #4 flat head machine screws: 4-40 and 4-48.
roger lance
Try a business called the Bolt Depot.....I've had good luck with them.
johnv
Ace hardware stores around here carry what you want. If you want to go into one right now.
Ditto on Bolt Depot
Tim Greif - West of Chicago
Bolt Depot -- I've bought a fair amount of nut and bolt hardware from them. They had stuff I couldn't find readily anywhere else. Good outfit. Not affiliated, just a satisfied customer.
Kneale Brownson
ANY good hardware should be able to help
Search for micro or miniature fasteners
Don Stephan
Perhaps the first step is to identify the actual size and thread count. A good hardware store will sell thread gauges, imperial and metric versions, and likely will have available diameter and thread count gauges for use. Ideally they also will have the correct nuts. Then you will know what size machine screw to look for at the various sources.
When the need arises to hacksaw a machine screw or bolt shorter, I like first to thread on a matching nut beyond the planned cut, hacksaw away, then unscrew the nut to help straighten out the cut thread at the new end.
From an electrical supply store or well stocked department years ago I purchased a pliers that has built in cutters for common small machine screws. Screw in the item, close the pliers to cut it off, and unscrewing will straighten the threads.
Lee Schierer in McKean, PA
Many of the wire stripper/cutter multi tool pliers have built in bolt cutters that include #4-40 threaded bolts. These will cut you screw with much less effort than a hack saw with smoother cuts and less touch up to make them functional.
Another trick when cutting screws is to screw a couple of nuts on above the cut line so that when the cutting is done you can screw the nuts off which will clean up the threads to a degree.
Lee
Another for bolt depot *LINK*
John in NM
I like them as well as McMaster-Carr and use them for bulk orders where saving a few pennies per screw starts adding up to real money (last time I bought 1000 2 1/4" 8-32's).
4-40 is the most likely size, 4-48's are a bit oddball these days, but you can still buy them. On a #4 screw the difference between fine and coarse thread pitches is almost moot.
#4 machine screws are a bit small for the average hardware store to stock, so I would recommend calling ahead if you want to check your local Ace. Saves a lot of driving around.
https://www.boltdepot.com/Product-Details.aspx?product=1598
Pete in Holland MI
Your local hardware store with the aisle full of the little drawers of various fasteners should be able to have what you need. Most threads are pretty standard anymore. Bring the screw & pull with you when you search. I've never seen them, but there may be metric screw pulls out there.
Hardware store
Ralph Lipeles
My Vaco wire cutter/stripper has tapped holes where you put in a screw to be shortened. Screw it in until the screw is the length that you want and then squeeze the handles to cut the screw. One of the tapped hole sizes is 4-40.
Andy Lincoln in Dearborn,MI.
https://www.boltdepot.com/Machine_screws_Phillips_pan_head_Zinc_plated_steel_4-40.aspx
Johanna Johanson
I did find the correct bolt at Home Depot - I had not realized they carried some metric hardware.
Thanks to all who responded - I now have saved the info on Bolt Depot and also know that my wire cutters might be good for cutting bolts as well.
Today I'll finish sanding the little box and get some shellac on it. I plan to make one more, so I bought enough 3/4 inch bolts to use on the next one, too.
