Porter Cable Half Blind Dovetail
Stuart Johnson
I'm having an issue when making half blind dovetails with a Porter Cable jig. The tail board is 1/2" with face 3/4". They are the exact same width. With them set up properly in the jig they are not fitting correctly after being cut. One side is high by about 1/8" and the low by the same amount.
I know how to fix the depth and how tight the joint fits but I can't figure out how to adjust so the sides and front match. Any ideas?
Re: Porter Cable Half Blind Dovetail
roger lance
Please identify which P-C jig you have and owners of that jig will be able to easily answer your question.
I have an old P-C Omnijig which has adjustable tabs that dial in the correct offset.
Re: Porter Cable Half Blind Dovetail *LINK*
David Yoho
I have an old model 4112. Here's a link to the User's Manual that should help. I think page 7 will help answer your problem.
instruction manual model 4112, 4113, 4114, 4115
Lee Schierer in McKean, PA
The stops for the slots and tails are not aligned properly OR you have some debris that is pushing the pieces to the side which is causing the offset you see in your parts. Make sure your pieces are pushed tight to the stop each and every time. If the pieces you show were run on the left side of the jig as you face it the stop for the slots is about 1/16" to far to the left as compared to the stop for the piece with the tails. Run some scrap pieces after you make slight adjustment.
Lee
