A55 Smoothing Plane
Mushroomed steel wedges
Ryan
Taking a detour from chain saw chaps, into the (surprisingly) dangerous mushroomed steel wedges, what is the best way to clean off the mushroomed bits? I've been using an old one that belonged to my dad, well mushroomed and never thought anything of it!
Re: Mushroomed steel wedges
If badly mushroomed toss it and buy another. I keep mine tapered inward by grinding as needed. I have seen some at flea markets that would wear out a grindstone to get in safe condition to use.
I have a lump just above my hip joint that is a 3/8" piece of imbedded shrapnel from another instance of a piece of metal ejected from a wedge. Now I wear chaps and industrial strength safety glasses.
Lee Schierer in McKean, PA
Find someone with a plasma torch or a cutting torch to remove the mushroom. Then grind them frequently to keep the mushrooming under control.
Lee
William Duffield
With the performance of the current crop of plastic wedges, It would make sense to me to just dispose of all the old steel wedges. I don't use mine any more. The risk is just too great. These seem adequate for my uses, anyhow.
https://www.amazon.com/Felled-Spiked-Felling-Wedges-Cutting/dp/B07GZXZ2Q6
What am I missing?
Dick Coers
Cutoff wheel in a right angle grinder. I cut through the mushroom at an angle so it’s now beveled.
That is what I do too
Re: plastic vs steel wedges
Rum
Those plastic wedges are felling wedges not splitting wedges.
I'd NEVER use a steel wedge as a felling wedge, that would be a great way to end up with bits of chainsaw chain coming back to visit you. For holding upen a chainsaw kerf plastic or wood only.
On the other hand try splitting a block of anything with a plastic wedge and in pretty short order you don't have a wedge.
William Duffield
I was using them last week to split up some dogwood to make some dogwood wedges. So far, they seem none the worse for wear, but I haven't abused them a lot. They are made by Chestnut Tool, and they do have a warning on them to wear eye protection.
Joe shelton
I've had some success using what Roy Underhill calls a "glut". Just a wooden wedge, with an obtuse angle compared to steel and plastic wedges, but effective after the split has been started.
rum
I assume you got the split started pretty good with an axe or something before using the plastic ones?
Once a split is started I can see them being helpful to move it along with some woods. On some of the local white oak I have to use a sharper steel wedge to even get a heavier wedge to start and then have to wail on the bigger wedge pretty heavily to move it at all. Usually finish with some even bigger wooden wedges and then axe cut the remaining.
William Duffield
Yes, your assumption is correct. If the wood does not already have a substantial check, I usually start with a splitting axe. I'll just chalk my question up to a lack of imagination.
