Rub joints
Rub joints are made by adding glue to a joint and rubbing the parts together until the glue sets up. Rubbing squeezes excess glue from the interface. When most of the glue is squeezed out, the remainder looses water to the wood and the viscosity of the glue film shoots up. The joint becomes immobile to modest pressure. With time the joint cures as the remainder of the water diffuses into the wood.
Rub joints are used to install parts that would be inconvenient to clamp, such as corner blocking in case pieces, as shown on the skirt of this Period Hall Table.
The topic comes up among the hide glue enthusiasts as an advantage of hide glue, implying that other glue will not offer the opportunity to use rub joints. This presumption is not true. White and yellow glue make rub joints that are entirely satisfactory.
As an example I put a drop of glue on the mating surface of these sticks and rubbed them together until the joint seized. I allowed the joint to cure a day and then tried to break it. I could not with just my hands . Eventually I broke it by clamping it in a vise and bashing one piece with a hammer.
Close inspection revealed torn wood fibers all along the glue joint, illustrating a bond as strong as the shear strength of the wood. Good enough.
