Finishing frame and panel assemblies
The first frames and panels I ever finished were some 6-panel factory doors for a friend. Sprayed with NGR stain and finished with conversion varnish. That winter there was a "white" border around each shrunken panel. Note to self, pre-stain panels.
There is no perfect way to handle the issue of panel size changes. I am curious how others handle this issue.
I prestain just the raised part of a raised panel. After the whole of whatever this panel goes into is assembled I stain the rest and apply finish. This approach leaves the possibility of a stained but unfinished border showing when the panel shrinks.
Or I stain the whole of the panel and apply the first sealer coat of finish to the panel before assembly. Then assemble the whole of the piece, stain the frame and top coat frame and panel. This approach leaves the possibility of a discontinuity showing in the finish line when the panel shrinks.
