Need vice for dovetailing "in the field"
I am going to need to make some drawers away from the shop. Does anyone have a plan or picture of something to hold drawer parts for sawing that can be fastened to a heavy table top?
I hate building shop furniture and spending money, so cheap and easy is preferred.
I am thinking along the lines of an "angle iron" built from wood that could be clamped to a table top and then some sort of threaded clampy thing that would capture the drawer side, front etc. afainst the vertical part of the "angle iron". What is available for threads and clampy thing remains fuzzy.
Re: Need vice for dovetailing "in the field"
roger lance
You've made a good description of a Moxon vice. You can make one as fancy or plain as you see fit.
Would Toggle clamps work? *LINK*
Keith Newton
I've got a big tub of them around here somewhere. I usually use then on templates or places where I need a third hand.
https://www.thetoggleclampstore.com/201b.html?gclid=CjwKCAjwkYDbBRB6EiwAR0T_-i6iCa3HQ7aTJgEJvmYUDHxRORoAMUajbMLDTn93zYng5r9zFffTjBoCuNUQAvD_BwE
Jack Guzman from Maine
moxon
Bill, I built this from a picture in the workbench book years ago and use it every time I dovetail. A little more than you wanted but you will use it again. All you need is a couple blocks of wood and a screwbox kit.
Moxon vices......
roger lance
My vice is on the fancy end with hardware from BenchCrafted......they have a set of plans on their site which explains their hardware and has dimensions for a build of this type of Moxon......
There are untold numbers of examples of Moxon builds on YouTube with people using all kinds of different hardware or making use of various clamps to make their vice.
Now that's what I am talking about
Bravo! You understand easy and cheap. I have lots of clamps and lots of wood. But, I don't understand the screw locations. However, I think I will just groove the ends of the jaws and slide a clamp, with head, into the groove. The grooves will hold the clamp in place and the front clamp jaw will close the wooden jaw.
Re: Now that's what I am talking about
Larry Barrett
Here is a Double Bench Screw I made based on Jennie Alexander design. I used 16 penny nails to hold the clamp head in the slot. Because the clamp screw is angled, I needed to add the extra nail to keep the clamp from sliding sideways when tightened.
That clarified the nails
Thanks, now I see how it works
Question
Do you see any disadvantage of leaving the top jaw on the clamp and using it to pull the wooden vise jaw closed?
I saw dovetails different from most. I start the saw at the back of the cut and then bring the saw level to complete the cut. Because I don't tilt the saw handle down in the process it would seem that the clamp jaw would not be in the way.
On the other hand when I examine a clamp I may find it easy to remove a jaw.
Unless it's important for the nail heads to be flush or counter sunk, why not use scaffold nails (double heads) so they would be easy to pull out when teh time comes to disassemble. I like the design.
Also called Duplex Nails.
Re: Question
Larry Barrett
Alexander very much disliked having any metal on the front side of the Double Bench Clamp for fear of hitting it with a saw or chisel. I can see the point. Same reason that the nails are recessed.
If that doesn't bother you, then leaving the F-clamp head on should not be an issue. Removing the head was easy on the clamps I used. I kept the heads in case I ever want to restore the F-clamps.
Larry Barrett
I drilled the hole for the nail all the way through. So easy to remove the nail by just poking something up from the bottom.
Clamps
I think I will rig something with my beloved aluminum bar clamps. Will report on project when it is evaluated.
Jim in Burlington Ont.
Tail Gate
I remember cutting dovetails for ... on the tail gate of her pick up, used clamps, I am sure they are still tight in the table they went into...
Take Care, Jim
