Sanding Question
Sanding Question
Sanding Question
Kevin French
I work with mostly used quarter sawn oak wine or whiskey barrel staves making lamps from them. My sanding usually starts at 60 grit with a ROS, 80 grit with a ROS followed by 80 grit by hand especially to work the long edges to even them out. Then I wet the wood to raise the grain.
Which is where my question fits in. When the wood drys I hand sand, with 80 again or move up to 120 grit?
120 with a ROS, raise the grain 120 or 220 by hand.
220 with a ROS, and finish with 220 by hand.
Then I use vinegar that has a steel wool pad resolved in it to stain the wood and hand sand to 320 when dry.
Finish is usually Antique or Tung Oil.
Most likely it doesn't make much of a difference but when one is down in the shop one gets to thinking, a lot.
Re: Sanding Question
So where's the question?
Re: So where's the question?
Kevin French
Is in the middle of the post
Too much sanding
I must admit I got lost in your sanding schedule. Which surely means it is way more complicated than it needs to be.
While the rule of thumb is skip every other grit size I find I can not skip 80 to 120 and be rid of the assault from the rocks in 80 grit.
What are you accomplishing with 60 that requires such a coarse grit? (I have never examines an oak stave in detail. )
Sanding beyond 120 to 150 on this project is probably over sanding to no detectable benefit.
I think you are wetting way too early in the sanding/finishing schedule. Wetting is to raise the grain from sanding. It makes no sense to wet followed by sanding that will result in a need to grain raise some more.
I would try- sand 120, wet, sand 120, stain, lightly sand with something finer if needed.
Re: Too much sanding
Kevin French
The 60 grit is needed to remove all the stain and rust by the barrel hoops.
Wow, that must make a mess. I think I would be doing this task with a belt sander. The scratches would be parallel to the length and any sanding defect not so obvious as circular swirls.
What does a finished lamp look like? I was presuming something rustic given the raw material, buy maybe not.
I would be coming up with a dye stain that achieved the desired look and ditch the water and its grain raising issues and steps.
Dick Coers
I agree with Bill. 60 grit on a random orbit scratches must be miserable to remove. 80 grit on a belt sander will be much quicker. I don't go backwards with grits after whispering, but then again I don't use those coarse grits.
Mark Hennebury
Run it though a thickness planer and finish with 120 grit.
Don Stephan
If you are comfortable with hand planes, you might find that a few minutes with a block or slightly longer hand plane will remove the top bit of wood and the stains faster than the sanding schedule.
One sentence caught my attention - you are sanding the long edges to "straighten them out?" Not sure how straight a ROS, especially with coarse grits, will leave a long edge. A long sanding block or hand plane should leave a straighter edge if you will be joining the staves together.
Kevin French
I've tried a BS but you really have to be careful or you screw up the crown of the stave, it's not a flat or square piece of stock every dimension is curved, cut on an angle or both. I don't have a problem with the ROS swirls when I raise the grain between sanding.
I like the look of the vinegar solution it gives them a dark weather gray look that a lot of people like. Also a quick hit with the 320 after the staining drys makes it baby smooth.
The one I'm building now will be like the color of the dark one, with the disk placement of the flute, but will have 1 1/4" black tubing instead of an instrument.
Kevin French
No, you'd ruin the characteristics of the stave.
Kevin French
I'm hand sanding this long edges to remove the facets that a powered sander leaves when rounding over the edge.
Kevin French
And you're also not sanding almost rough lumber.
The extra time with the ROS is worth the effort over the flat spots I got with the BS.
Might be a job for a spokeshave.
I would like to see a picture of the end product.
Kevin French
I will post a pic when its finished, the center tube is painted and the wood has its first coat of oil, so it will be Monday or Tuesday before I get to wire it.
So let me simplify the question
Kevin French
If one was to raise the grain when the wood dried would one move on to the next finer grit?
probably
after water treatment, I would move on to the finest grit that would yield the smoothness desired, determined by experiment with material at hand.
I have never grain raised after 80 grit so I have no idea what it would take to smooth at this point. But, I don't know why I would be grain raising at this point. I would grain raise after the grit I intended to use just before staining, which in this case would be 120 or 150. Having never sanded a barrel, if faced with this task and what you have said, I would grind with 60 followed by 80, 100 and 120, grain raise, 120 and stain. that is my best guess from sanding other stuff.
I would try planing these staves. I think the result could be attractive. It is surprisingly easy to hand plane a convex surface. I have done it on curved drawer fronts and other products using a #5 plane. It takes but a couple of minutes to plane the band saw marks away after sawing a curved drawer front. Leaving some planing facets on the stave could reflect light in an attractive way. Water based dying will not raise grain on a hand planed surface .
Re: probably
Kevin French
I'll put the #5 to a practice stave, the only problem I see is your draw is convex in only one direction and a stave is convex in two.
Thanks
Re: probably
Bruce, a MN Galoot
Try the #5 or a #4. It’s easier and more effective than you think. A good block plane would work, too.
Leo Cuellar
Leo Cuellar
Try sanding at the coarser grits while the wood is still damp. You will go through more discs, but you will also be able to remove wood much quicker. Apply more water to the problem areas. This method really only works well with a ROS, or a BS with cloth belts.
You can do this with every grit, but, you want to let the wood completely dry before the last grit.
Re: Sanding Question *LINK*
John McGaw
I think that, if I were engaged in a lot of similar work with similar materials, I would invest in a decent sanding brush of suitable width and grit to mount in my lathe for at least the first cleanup pass.
Sanding Brush
Good Idea. I just made a sanding mop out of some 80 grit cloth backed sandpaper I had an abundance of. Used it to round off and "Pillow" some blocks of scrap. I bet it would do a number on those barrel staves.
Kneale Brownson
Was there supposed to be a picture?
Kevin French
It looks like it would if a. I had a lathe and b. if I had room in my 11x11 shop for a lathe. :\
Flat spots with a belt sander
Dick Coers
That's a technique issue with the operator, no the machine. With practice it would be a great time saver for you.
