What Bandsaw blade?
What Bandsaw blade?
What Bandsaw blade?
I have a 14" Delta bandsaw with riser block. I think it's time to buy a carbide tipped blade for resawing. What blade do you use for resawing? Carbide tipped? What blade would you recommend?
Re: What Bandsaw blade?
AZ in Colorado Springs
I like Timberwolf blades from Suffolk machinery. A few months ago I got a wood slicer from highland hardware. I tried that because many folks here recommend it. I can't tell much of a difference in use. Same performance but more expensive.
Admittedly, this is a small sample size, but I'll stick with Timberwolf blades.
I work mostly with maple, walnut, and poplar.
David Yoho
I don't think you'll gain anything on that saw using a carbide tipped blade for resawing that one of the better non-carbide blades will do for you.
I'm fortunate to have two bandsaws. The 14" Delta without riser does all the normal and curved cuts I need using regular blades. My Mini Max 16 is set up with a 1-inch Lenox Tri-Master carbide blade for resawing and cutting large stuff. The MM-16 can tension the wide blade easily and has more than enough power to cut through stuff the Delta would struggle with. Save yourself the extra money and just use a good blade on your Delta.
Hi Barry
Choosing a blade width and compoition depends on how much tension your bandsaw can sustain. Carbide blades are the stiffest, and I suspect that none will be tensioned sufficiently by your bandsaw to work satisfactorally. Without enough tension, their performance suffers noticeably. The only carbide blade I would suggest may work on your bandsaw is the Resaw King, as it is the thinnest and requires the least tension. I am not sure how wide they are, but you could not go wider than 1/2".
Next in the chain are bi-metal blades, and you may get away with one that is no wider than 1/2" (in reality, a 1/2" blade is capable of a wide range of cuts).
I would stay away from the Woodslicer blades. They do cut well, but the steel seems very soft, and they do not hold an edge for long - especially in my West Australian timbers.
For reference, I use a 1" Lenox Woodmaster CT for resawing and 1/2" bimetal blades from a local supplier for all else. I resharpen these myself, and get about 4-5 sharpenings per blade. My bandsaw is a 17 1/2" Hammer N4400.
Tuning the Saw
Don Stephan
Regardless of the blade, tuning up the bandsaw can have a significant affect on quality of any cut. One time I saw an ecellent video on the Internet walking through the tuneup, and I'm hoping someone here will have a link to it. Think it was by a bandsaw rep, but not positive.
Re: Tuning the Saw
Don ..
https://www.youtube.com/watch?v=wGbZqWac0jU
I have a 14" delta and a larger saw. The 14" may not be able to tension a carbide resawing blade effectively without damaging some parts. The tensioning bracket on mine warped and I had to replace it with a stronger one from Iturra Design. The tensioning spring may also need replacing.
I use a 1/2" 3 tpi for almost everything on my 18" bandsaw including resawing. However, I don't try to get smooth resawn surfaces - I run pieces through a performax drum sander if I need them smooth. (most of what I do is cut blanks for woodturning, many of them to the capacity of the saw).
Re: Tuning the Saw, I haved tuned....
the saw within an inch of it's life. I bought boxes of 1/2" 3 tpi blades for cheap and treated them almost as disposables. I think I have twenty or more I think I will take them to a local shop for sharpening. Takes me about fifteen minutes to "sharpen" one and I would rather be woodworking.
I was hoping to find one that would last longer. I hate fiddling with the saw.
Brad Patch
Check out Cutlery Mania on Amazon. They have a wide selection of bandsaw blades intended for meat processing. The Woodslicer brand was derived from the same meat/bone cutting industry. The only difference that I note is the cutlery Mania blades do not have the irregular tooth spacing. I tried one on my 20 inch saw and it performs very well. I intend to only use it sparingly as it will dull quickly the same as the Woodslicer, but at half the price it was worth a test.
carbide on 14" saw
1. I was at a SAPFM meeting where this topic was discussed. A participant was successfully running carbide on a 14" saw. The bottom line, ask Lenox if it will work.
2. A friend runs carbide on a large saw. It yields cuts that are so smooth they can be glued as veneer without further treatment.
3. I doubt tensioning is the issue to be concerned with. Rather it is bade fatigue running over the smaller wheels. Lenox will know if fatigue will be unacceptable.
Bruce, a MN Galoot
For lots of resawing I have a Lenox Trimaster on a 14” Delta without a riser. It does a very good job, maybe not as smooth as the Woodslicer, but it is long lasting and it will cut through anything.
Plus, it can be resharpened, a good thing since the cost will take your breath away as fast as a MN winter.
Jim Dillon
Barry, for resawing I have been happy with the Lenox Tri-Master carbide-tipped blade on my 14-inch Delta with riser. Years ago I (like JKJ mentioned) did replace the tensioning bracket and spring from Iturra Design so that might have helped achieve proper tension. Yes, the blade did finally break at the weld but that was after resawing a lot of Jatoba (Brazilian Cherry) - a VERY hard wood. I bought a new one immediately as I was so satisfied with its performance. One has to take time cutting on the Delta and not push it. I lust for a bigger bandsaw, but don't have the room and the Delta suits my hobbyist needs. For normal sawing, I like the Timberwolf blades. I tried the Woodslicer but concluded it was overrated. Hope this helps. Jim
So, I talked to Lennox....
called Tech Help line and got Rick. He was very nice and took a lot of time with me. He knew I was hobbyist and not buying pallets of blades.
I asked about the Carbide tipped tri Master. He said it would fit the saw and run OK, but did not recommend it for resawing. Said the saw runs too fast and the blade would develop a lot of heat. And, 1/2" wide blade was not really wide enough for resawing. Should be 1" or 1 1/2" wide. His thought was the carbide was a waste of money and I could buy three bimetal blades for the same price. I am going to try them.
I also discussed using cheap blades and sharpening them. I must have 15 or 20 blades I paid 10 to $15 each for. Told him I was thinking of taking them to a saw shop and having them resharpen them for $5 or 6 each. He pointed out that the quality of the blade after resharpening is totally dependant on the equipment they have and the skill of the operator. That one batch may come back excellent, good as new and the next batch may be worthless. You are spending $6 to avoid spending $15 and getting an unknown. Why risk your wonderful piece of wood?
My problem is that what I have done in the past is buy a box of a dozen cheap blades. I have found I can do excellent resawing with a blade right out of the box. But, with an hour of use or less, the quality degrades and I can no longer do good resawing. So, the plan was to put a fresh blade on the saw, do the resawing and then put the old blade back on for general use. Where the plan broke down, was, I hate changing blades, so I didn't do it. I left the new blade on the saw and the slightly dull one hanging on a nail. After a while, I can't tell which of those blades is really dull and which could be very worthwhile. Clearly would have been smart to label them.
A lot of this report puzzles me
"Said the saw runs too fast"- 20-36" saws have blade speeds much faster. But if you believe the saw runs too fast, change pulleys.
And, 1/2" wide blade was not really wide enough for resawing." Maybe not ideal but perfectly adequate as anyone with experience resawing knows- I have done a lot of resawing with 1/2" blades. It is teeth per inch and tension that is way more important than blade width.
"paid 10 to $15 each for". $10 will buy from Misenheimer a Lenox or Starrett blade that the furniture factories use . I would not call these "cheap" blades. This same steel is used on wider less teeth per inch Wooodmiser saw mill blades that cut miles of wood before discarding.
"But, with an hour of use or less, the quality degrades and I can no longer do good resawing." I resawed drawer sides for 3 hours yesterday from dry poplar billets 6 to 12" tall. The "ordinary" Lenox bade was far from new when I started and it was still sawing fine when I stopped.
Re: A lot of this report puzzles me
I agree.
I wonder about a lot of it. I think he is basically a metal worker guy and is looking for that type of work.
Every wood worker with a bandsaw has similar or faster blade speeds.
It seems to me that blade speed, tooth count and feed rate are all related. I have read that the number of teeth in the work piece is important. Tooth geometry is important. There is a lot about ability of the teeth to carry the chips out of the work piece.
I may have exaggerated about the time. Whatever the time is, it is more than an hour or two, but not very long. It seems to me that these blades are not nearly as durable as a table saw blade. I needed stickers for the wood I had cut off the family farm and literally ran a mile of pine across my table saw and then kept on using the blade.
When I bought my bandsaw they shipped me a different saw with a transmission on it. You could change gears and cut metal or wood or whatever. Turns out that about tripled the price of the saw so they came back and got it right quick.
John in NM
I would agree that heat is probably not a factor. Cutting metal you get heat problems but I can't say as I've seen it with wood.
I get cheap blades, really cheap. I buy a 100' roll and weld them myself (brazing is cheaper and easier and also works fine). BUT I do not get a fantastic cut. I get an average cut quality from a $4 blade. They will resaw nicely when new, but not perfectly, still needs planing before use.
Bottom line as I see it, if you want great quality cut (like for minimizing waste when resawing) try a carbide blade and see for yourself. As Bill suggested earlier, the big question is whether the heavier blade will stand the bending of the small wheels.
If you want a cheap blade, make your own or buy in bulk from an outfit that makes them up from stock. Another to try is Supercut blades - though I remember those being $10 or so too.
You could sharpen blades yourself if you want - get a chainsaw file and a saw set and have at it. You'll probably spend close to an hour on a blade that cost less than $10 - doesn't seem worth it to me.
I routinely sharpen blades with a metal-cutting disk on a dremel, sharpened on the front only. It takes me about 20 minutes to sharpen 400+ teeth on a 3 tpi blade for my 18" Rikon. When I sharpened blades for the 14" saw it was a lot quicker.
Good to know...
John in NM
I'm a bit surprised you can resharpen without adding set however. I may have to give that a try and make my $4 blades into $2 blades! :D
Walt
Bi-Metal might be a "sweet spot" on 14" cast iron saws. Lot of people like the Lenox DieMaster 2. Bi- Metal should stay sharp longer than the cheapie carbon blades but not as long as real carbide tipped blades. A blade that interests me is SuperCut's resaw blades but I've never used one.
http://www.supercutbandsaw.com/woodsaver.html
They're a little deceptive about calling them carbide blades when they're not in the usual sense of the word. I have some of their Premium Gold blades and they last pretty well.
Only sharpen the back of the tooth.
Sharpening the front of the tooth will alter the rake and the way it cuts. Sharpening the back of the tooth simply removes the wear.
I use a Dremel and a cheap diamond disk (from eBay) to stroke the back of the tooth. You are removing a minuscule amount of steel. This does not alter the set. I generally resharpen a bimetal blade about 4 times. Each time it comes out like new.
Re: how do you hold the blade?
Hi Bill
I leave the blade in the bandsaw, get it up to full speed, and then jab down really fast with the Dremel to hit the back of each tooth. You gotta be quick! :)
No, I do leave the blade on the wheels, and then rotate it by hand. As each tooth comes up, I stroke the back.
It takes about 15-20 minutes for a 3 tpi 1/2" bimetal blade on my Hammer N4400 (your average 18" bandsaw size). It takes about 10-15 minutes for a 1" 1.3tpi carbide Lenox.
This is a Lenox Woodmaster CT (carbide) after 3 sharpenings. There is still plenty to go ...
(Message Deleted by Poster)
Re: I only sharpen the front of the tooth.
John
Your photo shows you sharpening the back of the tooth (not the front/face).
OOPS, I thought the FRONT of the tooth was the part facing me! Thanks for pointing that out!
I know others who sharpen only the gullets.
Sorry. May I plead temporary drug induced mental deficiency due to oxycodone? I'm in the currently enjoying Fun With Kidney Stones and trying to hold out for surgery scheduled next Wednesday. I spent New Year's eve in the ER watching the IV drip instead of the ball drop.
If I can manage it without messing it up completely I'll edit and repost it.
Thanks much for pointing that out!
