Craftsman Table Saw - Guides
Roger Furry
I have an older Craftsman 10" Table Saw and have a problem with the unique grooves on the top that don't seem to fit some of the newer feather board devices and jigs. I s there any way around this short of buying a new table saw ? The saw work fine.
Re: Craftsman Table Saw - Guides
Jack Guzman from Maine
Make your own
Joe shelton
For tenoning jigs, you easily can make a wooden runner. For mitering devices, look for integral adjustment capability. I don't think the feather boards need to be affixed into them, there are good magnetic options there.
Ralph Lipeles
I also use hardwood strips. If fit for accuracy is important, you can use small brass round head screws. Tweek as necessary until they barely touch the side of the table slot. For fixtures using both sloth I put the strips in the grooves, put some glue on them and then drop the top piece onto the glue covered strips. When the glue has set I reinforce the glue joint with some small screws.
Jim DeLaney, Austintown, Ohio
I haven't checked lately (Sold my Craftsman saws), but several online vendors used to sell miter bars specifically to fit the (oddball) Sears saws.
You might also check out some of the adjustable bars like the Incra, etc., to see if they'd fit.
Walt
The problem is likely that the miter slot is .750" Most miter bars are .750". A .750" bar won't slide freely in a .750" slot. Commonly miter slots are slightly over .750". Craftsman (and some Ridgid saws I believe) use undersized miter bars. At one time woodworking shows had vendors with undersized UHMW strips to use as miter bars. I don't know if they can still be found or not.
I wrote an article on the subject...
Rod Peterson--Ormond Beach, FL
...several years ago. I did a fair amount of research when I had access to a lot of machine tools. It was interesting drawing conclusions from that research. Perhaps some may find this useful. The short version is Walt's right, but you can get some more details in my article. Oh, and regarding the Ridgid tools? Emerson Electric, the manufacturer who used to produce Sears' saws also builds (built?) Ridgid saws. Same miter slot. Surprise?
http://woodbutcher.net/miterslot.shtml
Rod
Jerry Nicholson
I bought a Delta miter gauge several years ago and it fit perfectly on my 1964 Craftsman table saw. A few minutes of sanding on the bar on the Delta tenoning jig made it fit the Craftsman too. Actually, I think most of the sanding just removed the paint.
Jerry
