REAL MILK PAINT
Cross bar trestle table remade
Jack Guzman from Maine
I said I would post a picture when I completed fabricating the table leg system. It wasn't too complicated but it was fun to do. I got to use my router plane(half laps),Mortise chisels,and two different backsaws. I like the way it looks. The top is figured maple and that is also what I used for the legs. The client is going to do the finish.
There was some question as to the strength of the legs. I find them to be quite rugged. ---Jack
Re: Cross bar trestle table remade
Bravo!, Jack.....
Looks great, Congrats!
Nice!
How...
.....did you make the "coming together" joint? Not clear from the picture. It looks attractive however the legs and stretcher came together. Graceful.
Re: How...
Not sure what you mean by "coming together joint" but the legs consist of two "S" shaped pieces half lapped together in the center,and these two crossbars are joined to the stretcher with a wedged mortise and tenon. I made the tenons on the ends of the stretcher slightly proud and flared the outside of the mortises to lock the joint with a wedge in a sawed kerf in the tenon.
If this isn't clear I can take a close-up picture of the joint.
The joint deserves a close up pic
or at least I would like to see it. It can't be a run of the mill easy to lay out and chop half lap. How tall is the table? I was thinking this thing was a coffee table, but it looks to be taller
Re: Well done!
Close-up
Wow! the close up really shows the warts. Anyhow,you can see how the joint comes together better. The table is a breadboard end kitchen table. It is 30" tall.
good enough
I like the way you added material to this joint to strengthen it. That is the detail I wanted to see. thank you
It is a complicated joint to execute and it looks good enough. I doubt the client would have been interested in the cost of perfection.
Looks good!
Tony-Memphis
Thanks for posting. I bet that was tricky to lay out and cut. I have to admit my first thought when I saw the closeup was to chuck it up in the CNC router! I like the design. Might employ that in my next coffee table.
Tony
