Shop build advice -- outlet locations
A.J. Hamler
My basement shop build is proceeding apace. The framing is done and looks awesome; I think it'll work perfectly. Glad I agonized and planned and re-planned and re-re-planned it all to come up with the most workable arrangement.
Now, it's on to electricity. The electrician comes Wednesday to install the sub panel in the basement, followed by the outlets. I'm curious as to what you think about some of the outlets.
I've already plotted and marked out all the outlet locations on the studs and am confident they're all located perfectly to serve all my machines and portable electric tools -- plus ancillary stuff like where I want my radio, task lighting, battery charging and etc. and etc. I've already set the total number and type of outlets, too, so no questions on any of that.
For all my tools and general woodworking purposes, I've already set the height of the outlets intended for that. That is, I know exactly which outlets will be at the standard low height of 12"-18" off the floor, and which outlets I want at half-wall height for machines and over countertops. Ditto for my office and the storage room. Those are all good to go and no questions on any of that either.
However, I'll also have maybe six or seven outlets that are "unassigned" to anything I anticipate needing to use woodworking-wise. What's your opinion on the height I should make those outlets -- standard low, or high? Again, these are all extra outlets for which I have no planned specific use.
Keep in mind that one of these days we'll sell this house, and unless whoever buys it also plans to use it as a workshop the space will probably end up being either a family room or rec room. I want the place to be as "sellable" as possible
With all this in mind, what are your thoughts on those six or seven extra outlets.
Thanks!
A.J.
