Pinning tenons with brads - is this common?
Tim Greif - West of Chicago
I'm in the process of refurbing some old bar stools that I bought at Habitat Restore. They are well used stools that had been donated from a Hooters restaurant. Most are pretty wobbly due to loose joints. Some of the joints had been reinforced with steel angle brackets in an effort to extend their life. I figured I'd just knock them apart and re-glue everything.
When I started taking them apart, I discovered that most of the mortise and tenon joints had been pinned with 18ga brads. You can see what I'm talking about in the pictures. This makes things a bit more challenging, but so far, it's working out ok since I can deal with the brads without being a total hassle. These were made in Canada by a company called Holsag Canada.
This got me wondering why you would pin the tenons with brads. Perhaps to give longer life to a chair that's going to get a lot of abuse in a busy restaurant? The hassle is probably worth it since I only paid $12.50 apiece for the stools on sale. I have honestly not heard of this type of joint treatment before. Is this more common than I'm aware of?
Re: Pinning tenons with brads - is this common?
roger lance
Pinning tenons with brads is commonly done to hold the joint together while the glue dries. If you have limited numbers of clamps and a lot of joints to do; then, pulling a joint together with a clamp.....then pinning the joint....allows you to remove the clamp and go on to assemble another joint.
New Yankee Workshop Method
"Put a nail [ sic "brad"] in it 'till the glue dries."
Quick and dirty construction. Suitable for TV.
Now, if you're using good glue with tight M&T's, forget the pins.
Or, if you want increased joint strength, drill and peg the joint with 1/4" dowels
Or, if you want serious joint strength, use draw pegs on your tenons.
Don Stephan
Factory woodworking.
I'ver seen it often in factory stools
ebd
ebd
Where I want more strength I always used/use a blind fox wedge.
jesse cloud
I suspect those saying that its a hold-it-together till the glue dries strategy are right. Those brads bend easily and won't provide much strength at all.
Actually, when I am making a jig that needs two parts at a precise angle, I will often secure one with glue and a couple of brads. If the piece is off a skosh, a gentle tap on the brad held piece can bring it into alignment before clamping.
