WC Weekend Accomplishments....
Dennis E Peacock
29 May 2017
Good Evening Everyone,
Getting an early start to what's already been a busy holiday weekend. Been getting stuff done around the house, getting more of the bee hive box parts cut to include the interior frames. If anybody ever tells you that making those frames is quick and easy? Run the other way! Talk about a LOT of cutting and then assembly! Over 900 parts and I'm ready to call it quits. The good news is that my buddy and I have enough parts assembled to make 3 full bee hive boxes and he already has bees in both of his. I'm waiting until next year when I'll be more financially ready to purchase a swarm of bees.
We have out of state company visiting this week and I go back oncall next week. We cooked out hamburgers, turkey burgers, and hotdogs for Memorial Day as well as taking time out to remember all those that sacrificed so much for the U.S. country we call "home".
That's it for me, so what did YOU do this Memorial Day weekend?
Best of weeks to you all.
Dennis Peacock
Re: WC Weekend Accomplishments....
Well, I started on it mid week, on through Mon...
Keith Newton
I went down to my cabin along with my cousin who owns the cabin next door. He was wanting a floating dock like ours, so I offered to help him with it. Since we got a hunting lease across the creek from the camps, we need to take our 4wheelers across and back regularly, so I had converted a deck-boat into a work/ferry boat with boarding ramps. This has been working pretty well so far, but can be a bit dicy if you ride on forward on one side, means your backing off on the other side. With changing water levels, especially during and after a rain, at night while backing up a steep slope is just asking for trouble, plus causes serious bank erosion.
So we built the new dock with a wide enough fixed dock and gangplank to ride our 4-wheelers out onto the 20' x 20' floating dock, where we'll be able to turn around, then back onto the boat, allowing a forward exit on the other side. Then on return, driving on forward, and backing off onto the dock, where we'll turn around again then drive forward up the ramp.
We had already built the 40' long fixed dock, from which we then went out another 33' gangplank using bar-joist for the support. This wasn't fine woodworking, but will be excellent addition to our collective properties
roger lance
Well, from the weekend till now.....got the gas grill working. Involved getting a series of replaceable cylinders.....two of which had defective valves. Then, a series of trips to the local hardware for replacement parts for the grill......which included crawling inside the grill to disconnect/reconnect stuff. Hassle....
At 70, I don't crawl so good anymore into tight places.....but, we're grillin.
Alan Young
Spent my weekend dealing with water
Alan Young
Headed "Up North" aka here in Michigan as over the Mackinac Bridge into the Upper Peninsula to the clans cabin where my brother in law and I re-plumbed the entire cabin---used almost all pex so connections went quickly.
Then we found a water leak in our Mother-in-law's "new" cabin (ie less than 20 years old) a few doors away. My nephew dug a trench whiles neighbour and I did the hard work of running into town 18 miles away on a Holiday Sunday to get repair parts--
Down in this trench
we found this rusted out part
made a fix and moved some of the connections inside where the builder should have done it in the first place...
We celebrated our plumbing success with an off-road expedition to target shoot a shot gun with two other nephews- got this far and decided to call it a day---
Back home now and things look better:
I hate plumbing
And your post was a reminder why >(
The shot gunning sounded good though
Re: I hate plumbing
I'm a card-carrying member in good standing of the "I hate plumbing" club. But I should rephrase that - I love HAVING plumbing. I hate installing and working on it.
Jim DeLaney, Austintown, Ohio
Re: I hate plumbing
I know what you mean:
I Hate Plumbing!
So... About a month ago, after Sunday dinner, wife is cleaning up and suddenly says "We have a serious problem. The kitchen sink won't drain." Sure enough, it's half full of standing water, so I get the plunger.
Several tries with the plunger, to no avail, so it's down to the basement, move some stuff and junk out of the way to access the drain pipes and clean-out port.
Standing on a ladder, with channel-lock pliers in one hand and a bucket in the other, I gingerly unscrew the cap on the clean-out. Not quickly enough, I try to get the bucket under the pipe, so I get soaked in dirty sink water along with whatever else was already backed up in the 2" pipe. Yech!!! Of course, it's all over the basement floor now, too. Yech, again!!!
Trying a snake down the pipe yields no resistance for about 25 feet, then it's like hitting a wall. Half a dozen trips in and out with the snake gets me gobs of junk out of the pipe, but no forward progress, so I (after checking to make sure I had a no-hub sleeve in the shop's plumbing box, I cut the pipe at the 25 foot mark , using a recip saw. Found the blockage right away - I'd cut right into the middle of it. So, after cleaning as much gunk (technical term) out of the pipe, I ran the snake through it again - causing great gobs of gunk to fall out of the pipe onto the floor - neatly missing the bucket we'd put under the pipe. A few more passes with the snake got that part of the pipe cleaned out, then on to the other portion - beyond the cut.
Fortunately, that portion was only about six feet, into the main, but it had an elbow and two 45s in it, making getting the snake down it hard to do. Finally got it all cleaned out - after about an hour and a half.
By now, it's after 9:00 pm, and we've still got the floor to clean up and disinfect. Got all that done, went back upstairs, got out of the sewage drenched clothes, hosed off, and took a well-deserved trip to the hot tub, where I relaxed until bedtime. Slept well last night, though.
Next morning, it was back downstairs to mop the basement floor with disinfectant again and begin putting the shelves and other stuff back where they were before the debacle.
Can I say again that I HATE PLUMBING!!!
I Hate Water!
Jerry Nicholson
Water goes where I don't want it and refuses to go where I do want it! Like a few weeks ago when suddenly water was coming out the TOP of my water heater like someone had turned on a garden hose. I have installed a bunch of water heaters for myself and my inlaws over the years but this time I let a plumber do it. Cost me a bunch but it was really easy that way and I didn't have to make a single trip to the home store.
New on my hate list is my electric hedge trimmer. That thing got in an argument with the tip end of my left pinky on Memorial Day and the finger lost the argument. 8 stitches. Looks like the ER doctor played tic-tac-to on my finger. To add insult to injury, Memorial Day was also my birthday. Number 81.
Jerry
Re: I hate plumbing
Johanna Johanson
Me, too. When I was much younger and very poor I did my own plumbing repairs. The one that took the cake went like this:
Bathroom faucet leaking
A leaking faucet needs a new washer, right?
Disassembled faucet and took the rather strange looking washer (sort of cone shaped) to the big box store.
Could not find a match.
Tried another couple of hardware-type places - found nothing to match
Went to a plumbing supply - the fellow there said those washers were no longer available
Asked him what to do - replace the faucet, he said. So I bought a faucet.
Took the faucet home. Faucet did not match the sink holes.
Back to plumbing store with measurements of the sink holes.
"They don't make faucets with those measurements any more," he said.
So what do I need to do - buy a new sink!
Took sink home.
When I freed it from the drain piping, the pipe broke off at the wall. Grrrrrrrrrr.............
Went to big box store, bought appropriate pipe and connections
And, finally, was able to finish the simple job of a leaking faucet.
I don't do plumbing any more . . . I can afford a plumber.
Jerry you should have...
Let the plumber run the hedge trimmer and you do the plumbing. Probably less stitches.
Congrats on 81.
Re: Jerry you should have...
Jerry Nicholson
I probably would have burned myself doing the plumbing!
Jerry
