Table Saw Upgrades
Walleye Tom
So, I have this really old table saw. It is a 10" Craftsman Contractor Style. It has this goofy computerized system for raising and lowering the blade as well as angling it. If that ever goes out I am screwed as there is no replacement parts for that possibly 70's "High Tech".
It, of course, has a godawful sloppy inaccurate fence system and a 1hp motor off the back with the Belt. I was thinking about adding a decent aftermarket Fence system to it and a 1.75-2hp motor. I could even run a 230-volt motor as that and the computer part run off of different switches.
So, I have a few questions that perhaps someone might have the answers to. There is no wrong answer or opinions, unless it ends up with me in jail, again.
Are there any other ideas anyone has to inject this old saw with steroids and make it super impressive to the young ladies?
What are your recommendations for a good, not overly high priced Fence system that has a reputation for being accurate?
Also, with an aftermarket Fence system, do you have to build leg stands for it so the Saw doesn't tip over because it doesn't weigh a lot as it has an open bottom stand.
Has anyone ever built a "Custom" Cabinet type stand out of wood for the saw to sit on and maybe large enough for the added wings of an aftermarket Fence? Something big enough for storage and easy dust removal, on wheels, etc.
Has anyone "beefed" up their saw before by adding a larger motor to it? I am thinking more of a Power bump than a speed bump. I would keep the RPM's similar to the original 1 hp motor as I wouldn't want to overload any other parts on it. But that 1 HP motor on there now can get bogged down with some woods.
I know the Aftermarket Fence system will be worth more than this saw, but if I ever throw the saw away, I can use the Fence system on something else. As for the bigger motor, I will find one at an auction or garage sale, I won't buy a new one. And I have a use for the old craftsman saw motor in building a custom dual sander, with one side being a round sanding drum and the other side being a round sanding strip system. I will have to drop the RPMs using a belt and larger pulleys down to about 1300, but it should work fine. Great for Sanding odd pieces, especially Logs. I would get the sandpaper from Sandrite. They sell a system and I have the two different drums already. Grizzly sells one like it too.
That's about it. I sure would appreciate any and all ideas, advice, or expertise you might have. Thanks.
Here is a pic I downloaded of a cool cabinet with a cheapo old Craftsman table saw in it.
