I've got a Delta DC-33 planar and the manual describes an "extreme pressure gear oil" from Delta as the product to use when changing out the oil. Given the state of Delta, what oil do you recommend/use??
Any way to minimize the mess in addition to a bucket and rags??
If you can find an ISO number or something like that (I recall there being more than one system for oils) you can get an acceptable gear oil - I remember another person asking about this several years ago. The exact spec can be hard to meet, but substitution in such a case is not an unreasonable solution.
The use of an EP oil just tells me that they have a tight gear clearance - more so than a car differential probably. As long as you can find a similar viscosity oil that will maintain its properties when squeezed between the gear teeth you should be ok.
"A friend of mine has the 13", and the lube specs are the same as they are for the 15". They (Delta) told me over the phone I needed 140W with the EP7 (extreme pressure) additive. After a frustrating search, something tipped me off to Mobil 1 SHC 634 (Graingers, $20/qt.) and that's what I used and am using in my 15". That said, it's my belief that the specs are written for units that serve much heavier use than we hobbyists place on the machine....and that makes me think almost any heavy gear oil will work and the gear box will still outlive your ancestors. They are almost identical to all the other planer gear boxes, and I would bet almost every lube you can think of has been successfully used in them. My next change won't be for a while, but I won't spend a lot of time trying to find the stuff I use now...it'll be a quick trip to the auto parts store for whatever I can find. "
I've been using sta-plex extreme pressure premium red grease in my Delta planer, no problems (other than it smells bad). Google shows it's widely available.
Looks like what they used on a similar planer was 140 weight EP gear oil according to the link.
Most of us are familiar with SAE oil numbers since that's what you find in auto parts stores. At work I usually find ISO oil numbers, and they are often EP. Perhaps this is more common for industrial oils. Anyway, you may find more EP options looking for ISO 460 oil, that is pretty much the same as 140 weight.
You might find an EP additive at the auto parts store, then you could just use regular 85w140.
If it is a worm drive gear box (steel worm, bronze gear), steam cylinder oil was the industry standard for years until the synthetics showed up. I have several gallons for my steam engine if you get over to Holland some day.
If just straight gears, any heavy oil will be fine.
Hi Pete.....good hearing from you.....I just watched a Fine Woodworking video on YouTube: Masters of the Craft - Bob Berghorst.....I remember touring that shop with you years ago.....what a place!! (line shaft driven restored woodworking machines).
I'll be looking about for something suitable in a regular EP oil.....Delta's was $39.30/pint.....when you manage to run a company into the dirt, you can charge like that.
