Mirka backing pad
Mirka backing pad
Mirka backing pad
Joe shelton
Is it important to use some sort of intermediate pad when sanding with Abranet mesh disks? I ordered a variety pack thinking it included such a pad, but I was wrong. Are they too tough on the sander's hook and loop pad?
Re: Mirka backing pad
I use them on a Festo (early Festool) ROS without any issues.
Just be care that the surface is free from edges that catch the ends of the disk. This will cause them to tear. On flat surfaces they are fantastic. Ensure that you are hooked up to a vacuum -the removal of dust makes them work better. They last a long time.
Joe shelton
That's good news, Derek. Thank you.
I always use a backing pad
Dick Coers
I like the way it grips the disc, the sander pad really lasts when using the backer. I buy the multi pack backers from Mirka. I should mention, I use the automotive weight sanding discs.
Re: I always use a backing pad
Hi Dick
A backing pad is necessary for curved work. I have backing pads for that purpose. When power sanding flat panels with my Festo ROS, one does not want anything but a perfectly flat sanding surface. The Abranet mesh works very well with the hook-and-loop of the Festo.
For hand sanding (non-powered), I use this sander from Mirka ...
... which may be connected to my vaccum cleaner ...
