Paper clock face
Paper clock face
Paper clock face
Michael van pelt
What is the best way to attach a paper clock face 9 3/4" x 9 3/4" to a piece of 3/16" baltic birch plywood?
Tried some 3M spray adhesive but this gives you no adjustment. Once the paper touches the adhesive you are done>. Need something I can us and adjust the clock face square and flat.
Thanks
Mike
Re: Paper clock face
roger lance
why not attach the face as you are doing but to an oversized piece of ply that you can then trim down to a perfect fit??
One method
Gary Smyth
You might want to post on the photography side as well. This is old school. There might be something newer than 1970's methods.
There is a product called dry mount tissue. It looks and feels much like wax paper. Used to mount photos permanently to mats for display and is heat activated. The paper is thin and can easily be cut to shape and fit beneath the clock face (best if in one piece to prevent lines in the surface once heated for permanent placement). With a dry mount iron it can be loosely attached and adjusted to fit. Once set loosely in place it it is set to the substrate. This can moved for placement positioning. It is then ironed from the face. This is temporary until the whole is firmly and permanently attached as a sandwich---clock face/dry mount paper/substrate after being placed in a dry mount press.
The whole process should take less than five minutes. It is equipment heavy and experience based though.
Caution because it is heat sensitive you have to be aware of what you are doing. If it is too cold the binding won't work. If the heat is uneven or too hot it can darken the showing (clock) face. If the iron itself is dirty it can leave a permanent mark on the top item (clock face).
Any art frame shop or graphics house has the supplies and the equipment. One important piece is a dry mount press. To have them do the work would not be expensive, and they ought to know how to do it. If you have never done it before have it done. Ask around to be confident.
You tube has more than a few videos on the process "Dry Mounting Photos" -- take your pick.
If you use 3M
Gary Smyth
You can do a direct mount on an oversize piece of ply. By running a line through the center 12/hole/6 you can use a square to get the right angles to fit precisely the clock frame. Then you need to cut the perpendicular lines on the money, but sometimes it is easier to do it that way.
Re: If you use 3M
I think you can spray 3M 77 on just one piece and lay the other on it wet, slip it into position and then sandwich it under a flat plate and let it dry. Or roll it if you have a roller. Don't take my word for it. Practice on scraps.
George Koch
Premixed vinyl wallpaper paste? George
Ralph Lipeles
I've used regular yellow Elmers with good success. A homemade roller helps to squeeze out the excess glue.
Jerry Nicholson
I used double backed tape but it doesn't allow adjustment either.
It's still hold the clock face in place about 12 years later.
Jerry
Dave Bair
Liquid Hide glue gives a long open time and adheres well without bleed-through or clamping pressure. I use it to attach full-scale drawings to plywood to make templates.
3M adhesive
There are about a dozen of more 3M contact adhesives so that fact that whatever you used was inappropriate does not means hopelessness. . I can not see why what they call "repositioning contact spray adhesive" (approximate name) can not work. You get it at art stores. It has a tack a bit stronger than post it notes. Used to stick art work. I think I would have no problem getting one edge straight and rolling the rest of the paper down the substrate while smoothing.
BTW, I use it to stick abrasive sheets to glass for sharpening. Easy to remove spent sheets.
Re: 3M adhesive
Michael van pelt
Thanks for some great tips!
