Gagging at Track saw prices
Alan Young
Alan Young
I am working on this A&C Sideboard. The top will be 96" long and 18" wide. I have three beautiful pieces of Sapele for the top-each 9 feet long and over 6 inches wide. I need to edge glue them together. I have a 6" jointer-meaning its in/outfeed combined length is basically 48". I don't think that is long enough to produce a consistent straight edge on these boards. I can cut them shorter and "parquet" them in a glue up but I'd rather not do that if I can get these 9 footers glued together then trim to length. I have been looking at the track saws out there and they seem priced to gouge. If I did lots of carpentry work I could see investing in one- any suggestions on getting three 9 foot boards jointed straight for edge glue???
-Alan
Re: Gagging at Track saw prices
Hank Knight
How about a #7 or a #8 hand plane? I prefer a hand planed joint to a machined one for edge gluing, and I almost always take a shaving or two with my jointer plane after running the boards through my power jointer before glueing and clamping. Sometimes I skip the powered jointer altogether and go from the table saw to the jointer plane and then to the glue and clamps. There's a little technique involved in getting a perfectly mated edge joint with a hand plane, but it's not hard to do.
John McGaw
What I did was to chicken out. I have a 12" jointer and planer but the boards I intended for my dining room table where too big for that. I put out the word to members of the local guild and and a 'white knight' came to my rescue with the use of his big-iron shop. Dan Duncan ran the halves of my table through his 24" planer and even-wider belt sander. All that for a few bottles of wine from the cellar...
I didn't need to resort to his jointer though - I did the edges using nothing more than a long piece of hardboard as a guide and a high-quality finish blade in a Dewalt cordless saw. The joints weren't quite glueline ready but a touchup with my biggest plane got them so. Actually, it was planing those that convinced me that I really needed to have access to a huge planer and sander -- I realized quickly that I am pretty much totally lacking in Neanderthal woodworking skills and that bit of planing almost killed me.
As you note, the prices on track saws verge on the criminal. I'd have to be using one constantly for money-making tasks to even think about buying one.
Why not use a straight edge and a router?
I have just started to get a few Festool tools. Apparently I am late to the party. Noticed them on This Old House. Then on American Woodworker.
I would load you mine, but I think we are pretty far apart.
jesse cloud
Or a variation on Barry's suggestion... use a straight edge and a circular saw (or table saw) to rough cut the pieces so that they are straight, but not necessarily glue-line ready.
Then set up the straight edge and the router on one piece, clamp up the second piece parallel to the first so that the router bit will kiss both (a few spacers make this easy). Run the router down the gap and you are done. This way any irregularities on the angle or the straight edge will be compensated on the other piece.
Repeat until all joints are done.
Your jointer much longer than hand plane
Dick Coers
If your jointer is tuned up, and used with proper technique, it will work just fine for your task.
Re: another vote for router and straight edge
Dave Paine
I have used router and straight edge on long boards up to 96 in long.
Sometimes to glue pieces together.
Sometimes to glue on a piece of molding.
Sometimes to rout a profile on the edge.
You can rip a piece of plywood for a cheap straight edge. I have a commercial product which has two sections which can be joined together to give me over 8ft long straight edge.
Just take care with the setup. You may need a secondary piece clamped in the middle of the straight edge to prevent flexing.
John C Lucas
Ditto what Barry said. I had to repair a very long table top and the original joint was too bad to just glue back together. I bought a 10 foot piece of angle iron from my local machine shop ad used the router. Made a perfect joint.
John C Lucas
I have used that method but you have to be really careful. Because the bit is trying to cut on both sides it can really easily pull itself away from the fence. A very light cut and slow feed rate.works well.
Alan Young
This reminds me of the Steve Martin line:
Alan Young
Steve Martin: How to make a million dollars: First, get a million dollars.
Only for me "First get a straight edge- A LONG one...."
I guess I will brave my jointer first as Dick suggests. If I succeed-Problem solved-Otherwise I'm going to have buy something prefabbed and predictably straight-Then use my router....
Jim Dillon
Alan, do you have a roller stand or could jury-rig something to provide outfeed support? Granted, I have an 8-inch jointer, but have done 8-footers on edge. The key is placement of the roller so that it starts sharing the weight of the long board as it extends out from the end of the jointer table and before it wants to tip. Worth a try. Jim
Re: This reminds me of the Steve Martin line:
William Duffield
A tracksaw track meets those requirements. :D
I'll offer a few more rhetorical questions and observations:
You could match plane it with a #8, but that method requires time to practice the technique and keep the plane in tune. (You didn't mention the thickness of your boards.) An antique #8 (while much less expensive than a L-N at $475), may require some hours of effort to tune it up, and may require the additional expense of an aftermarket blade and chip breaker.
If you are having trouble making a straight cut in a 9' plank, you will have the same trouble making a straight cut to make your straight edge fence.
The time required to set up and make a cut with a tracksaw can be substantially less than some of the other methods that have been suggested, especially when you consider that one cut leaves you with two finished edges, with no chipout.
You can't hang your jointer infeed and outfeed tables on the wall to get them out of the way when you are not using them.
Controlling and collecting the dust from a router or even a typical circular saw and a straight fence is much more difficult than a tracksaw with a dust collector, cutting on a sheet of rigid foam.
The tracksaw has a zero clearance fence on one side of the kerf and a zero clearance splinter guard on the other side.
For safety, especially in ripping, a tracksaw has a riving knife. I don't see if on the circular saws I'm familiar with (or on my routers), and buying a tablesaw with one is kind of expensive. (I realize you probably already have a tablesaw, but much of what you can do with a tablesaw, a tracksaw with an MFT will do.)
I'm not trying to say they are not expensive, and I'm not trying to say a tracksaw is what you need, but in some cases, the tracksaw can be the right choice, and not that gaggably expensive compared to the effective alternatives, and when comparing prices to alternative equipment with which a shop may not yet be equipped.
How do you line up a roller stand?
Dick Coers
Seems to me you need a really good, long straight edge to properly line up a roller stand, and keep it in full plane with the out feed table. He's not talking about a piece of 8/4 hard maple that's 12" wide. He's talking about sapele that's 6" wide. Unless you have arthritic hands or other physical challenges, a 6" x 9' board is not that challenging.
Alan Young
I'm trying to not agree with you!
Alan Young
I've spent some money in recent shop upgrades and the next major purchase isn't really in the budget yet. I know if and when i get some version of a track saw I'll wonder why I didn't do it sooner- at this point I have been looking around for just the tracks-seems they can be joined for extra length but are still more than I "want" to pay at this time. Then I realized I may be able to "borrow" some 80/20 extrusions form work and cobble together a long straight edge--We have a bunch of 4 foot sections of this extrusion-I just matched up a few and they seem quite flat and straight----
McMaster Carr sells these 6 footers at $35.00 a piece-
Re: How do you line up a roller stand?
Jim Dillon
Gosh, I usually just eye-ball the roller stands' height. Usually the stand ends up being maybe 3-4 feet from the end of my jointer which leaves plenty of board still on the jointer bed to balance it. I do a dry run to make sure the stand is at the right height and that the board balances just fine. I can't find where Alan mentioned the thickness of the board, but I agree that a 6-inch wide board should be doable. I'm assuming the 6-inch jointer is fastened down to some sort of stand which might alleviate some excitement while jointing a long board and the jointer starts to tip.
Otherwise, I like the router route. But like Alan said, one needs a straight edge to cut a straight edge. So, if I couldn't scrounge up a long board with a straight edge in the shop, I would head to the local borg and buy a S4S 1 x 4 with a nice straight edge and use that. Jim
Andy Lincoln, in Dearborn MI
Alan,
I just sent an email to you. I can get access to our beam saw at work and turn those lovely long pieces of wood into narrow rips of sawdust pretty easily :) Of course you'd have to venture over to Dearborn.
Re: I'm trying to not agree with you!
William Duffield
Isn't that how we feel about most of our tools and machines (unless they're real lemons)?
80/20 extrusions have a reputation for being very straight and uniform, so it should be relatively easy to join them straight. I haven't used them myself, but I'm sure someone here has experience with them. The main advantage of track is that, properly adjusted, the saw cannot drift away from the track, even if you have a momentary loss of attention. Before I got my Festool TS 75 EQ, I made track from a strip of plywood and a 1x2, and glue and nails or screws. I tacked the 1x2 to the ply in one place, leaving the plywood a little wide, and adjusted it for straight by sighting down the length as I drove more screws in. (A laser level might help.) Saw the plywood to width to fit the 1x2 and the saw. This appliance has one annoyance. If you try to clamp it down to whatever you are trying to cut, the clamps get in the way of the saw motor. That's why tracksaw tracks have t-slots extruded into the underside with matching low profile clamps.
William Duffield
If the outfeed roller stand is set too high, the board will just push it over instead of rolling on top of it. If set a fraction of an inch too low, the only problem is the board will lift off the front of the table saw table as the balance point goes beyond the back edge of the table. That problem is not nearly as serious as the roller stand taking a coffee break, since the board can still be registered against the fence.
The roller stand must also be set very carefully perpendicular to the saw kerf. Otherwise, it pushes the board to one side or the other. If towards the fence, friction increases and the board becomes very difficult to push. If away from the fence, you get a curved cut. When I set up my outfeed roller, I adjust the height by pushing the board over the saw with the blade retracted. I find the easiest way to adjust its alignment is to measure the distances between the ends and the back edge of the table, and make sure they are both the same.
Rob Sandow
To accomplish what you are looking to do, I would get a long piece of angle iron or other suitably straight material and clamp it to the board. Then use a hand held circular saw to make one straight edge. Put that edge up against the fence of your table saw and run it through to almost final width. Flip it over, move the fence in to final width and run through again. Forget the jointer. If your table saw is set up well, you will get a glue-joint ready edge from it.
be optimistic
I once did a 16' piece on my 8" jointer. What is in your favor is that the 9' is going to have some flex such that you don't need to get it as accurate as a 3' piece. It may be necessary to have someone help with the outfeed by holding up the end. Pay her air fare and I will volunteer my wife. She is excellent at this task.
A dare....post this problem on the Hand Tool Forum :)
Michael van pelt
Hey! Any ol excuse to "have" to buy a new tool ain't so bad! You deserve a new Tracksaw and it sure would be a Festool! You might as well get a new vac
Avoiding clamp interference
AZ in Colorado Springs
If the motor on the circular saw is at the left of the blade (as mine is) then as you make up your cutting guide, let the plywood extend several inches to the left of your 1x4. Then the clamps are out beyond the saw motor. If your saw is the other way around, configure your cutting guide with the extra plywood width to the right.
TomD
The only thing track saws do is speed up the cut if you have on that doesn't need to be clamped, you can make the cut with any saw.
Since jointer planes are actually designed to do this, and you can make one in about an hour, the only reason not to use one is that you can't or don't like planes. A plus is that jointing boards is pretty much a no skill activity, if you can set up a plane to take a cut.
Henry (Raleigh NC)
My process exactly, and how I have lived without a jointer. I do buy S2S lumber, not rough cut.
I also am a hobbiest, not a full time WWer.
Henry
Alan, I rigged up an outfeed table on an Inca jointer planer that I had about 35 years ago. the jointer bed was only about 3 ft. in length total. The outfeed table had adjustable feet that I could dial in to accommodate my less-than-flat floor. I was able to joint perfectly straight edges on 13' bar rails, repeatedly.
